02-10-2018, 05:04 PM | #1 |
Rep 281
Passing inspection with catless dp
Hey anybody know where in queens ny where I can pass inspection with catless dp I will be needing it in 2 weeks thanks
02-22-2018, 05:10 AM | #3 |
Rep 106
Take a ride over to Autocare MLife, 11 Hendrickson Ave valley stream ny 11580, ask for Rick tell him Chevy sent you, them guys should be able to steer you in the right direction.
Ce
02-22-2018, 10:42 AM | #6 |
Rep 324
I don't think they're as strict. They used to do sniffer tests on the exhaust while the car was on a "dyno" to check for emissions. Now they really just plug into the OBD port and check for an CEL or any systems that aren't registering correctly. I had a Catless E46 M3 I would pass with out any issues because they had O2 bungs on them and my ECU was happy to see something registering so I didn't get any CEL.
to OP, theres a Shop on New Utrecht and 66th St in Brooklyn they may be able to help you... |
02-22-2018, 10:59 AM | #7 | |
Rep 881
02-22-2018, 04:16 PM | #10 |
Rep 812
If you cleared the codes you would probably fail the "Readiness Test" NY makes sure you can't just clear a code and then get inspected. You have to go through a certain time cycle before you can pass the OBD2 readiness test to allow the car to be inspected.
Formally known as BMWM3NYC
02-22-2018, 04:18 PM | #11 | |
Rep 281
