      02-02-2015, 10:31 AM   #1
ImpetuousRacer
ImpetuousRacer's Avatar
2013 BMW M5  [0.00]
305 vs 325?
I am looking for new rear tires (3??/25/21)
From my searching, everyone seems to be in agreement that that Michelin Pilot Super Sport are much better tires than the Pirelli P-Zero tires.
However, Pirelli makes a 325, where Michelin for the 21" wheel only goes to 305. I have the Michelin now with the 305/25/21, but when it comes time to replace, does anyone have experience which setup was the better one to go with?
Thanks.
      02-02-2015, 10:38 AM   #2
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Unless you go with wider fronts, I'd stick with 305. 275F/305R are a good balance, or 285F/305R would be even better. Wider rears and not fronts will just create understeer.
Matt
      02-02-2015, 08:57 PM   #3
HXS
Licensed Drug Dealer
HXS's Avatar
You'll need at least a 11.5 to go 325/25/21. Just a head's up.
      02-02-2015, 09:19 PM   #4
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Good points.
Also, the standard rear wheel size is 27.13" (19" 345M, 295/35/19). The alternative wheel size is 26.99" (20" 343M , 295/30/20). For 21" rims, the rear wheel size is 27" (305/25/21) and 27.4" (325/25/21).
      02-02-2015, 10:38 PM   #5
IANNUZZI
Drives: 2016 GoDZilla
There is a guy on this forum running r888s 285mm front and 325mm back on stock 20" M5 rims....
http://f10.m5post.com/forums/showthread.php?t=1086187
Informational
      02-03-2015, 08:47 AM   #6
mcvaughan
mcvaughan's Avatar
Informational
Yeah, I replied to that. I would not recommend a 325 on a 10.5 inch wheel. 305 max according to tire manufacturers.
Matt
      02-03-2015, 08:57 AM   #7
IANNUZZI
Does the M5 have have a 20x10.5" rear wheel or is that the M6?
      02-03-2015, 09:30 AM   #8
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
M6 has 20x10.5 M5 has 20x10
      02-03-2015, 03:03 PM   #9
ImpetuousRacer
2013 BMW M5  [0.00]
I'm working with 11". What's the adverse effects of 325 on 11"?
I take it the standars are:
305 on 10.5 (Available by Michelin)
315 on 11 (Available by Pirelli)
325 on 11.5 (Available by Pirelli)
      02-03-2015, 04:09 PM   #10
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
305 can be installed on 10.5"-11.5"
315 can be installed on 11"-12"
325 can be installed on 11.5"-12.5"
      02-03-2015, 06:49 PM   #11
HXS
HXS's Avatar
M6-Coupe gave a good answer on the second part, but I'm not sure about the adverse effects.
Maybe the tires won't bead properly on the rim? Not sure, but I wouldn't recommend it, especially on a 550-hp car.
      02-03-2015, 07:29 PM   #12
IANNUZZI
I just got an email from tirerack, 305mm is the max they are confident with on a 20x10 rear M5 rim. For more grip on the street and track they recommend the Michelin sport cup 2. Hope this helps....
