05-21-2013, 06:49 PM | #1 |
Rep 444
Accelerator lag
So maybe this is a common problem that I just don't know about but I was going in traffic today and all of a sudden all the power to the gas pedal was cut, I put my foot all the way down and nothing. This has happened to me a couple times now and I'm not sure if this is a commons problem in m5's but I don't wanna be stuck in a situation were I need the gas and I'm cut off because that could end pretty bad. Any advice would be appreciated, thanks!
05-21-2013, 06:51 PM | #2 |
Rep 837
I have noticed this a couple of times, but as far as I can work out it is under hard acceleration and the DSC cuts out the power in a very abrupt manner to prevent the wheels from spinning. It feels very abrupt. Has happened to me about 3 or 4 times in 18 months.
Not sure if that it what is happening to you. |
05-21-2013, 07:27 PM | #4 |
Rep 222
With my F10 M5 in all normal settings (defaults from ignition on) "gonowhereitus" is a problem I run into frequently.
If it is below 15C or raining it becomes more pronounced! The car is traction limited on any kind of loose road surface or a good road with even minimal sand/debris on it. Heck on cold tires + warm day it can be a handful in MDM/DCT off. To combat this I have my "M1" button set up: M Engine Dynamics (looks like speedo) = 3 M DCT = D3 (Auto shift most agressive) Suspension = 2 Steering = 1 (Comfort) Traction mode = leave MDM off as it requires a double click of M button to engage if MDM on/DCT off is selected (have that on M2) This way if I need to go in a hurry and notice the car is slower then a Toyota Corolla from the 80's running on 1 good cylinder you just need to tap M1 with your left thumb and your gone NOW. I do not enjoy driving the car out of M1 mode unless I am trying to take it easy on purpose (gravel driveway). This car requires "some" wheel spin to enjoy the drive. I am not surprised there is talk of new rear end/DCT programming on the M5 LCI. Hopefully it filters down as a software update as the above situation almost got me T-boned. One assumes a 560hp car can dart out quickly and get out of the way of another vehicle, but when it doesn't go anywhere and your almost hit you get scared to death! The flip side of the coin is the over-aggressive DCT in default settings allows my Wife to feel safe when driving it knowing the rear end won't kick out like when I'm booting around in MDM mode. I suppose the settings are the result of lawyers trying to nanny proof everything. This is one example where too much "safety" can be a bad thing! My 2 cents. |
05-21-2013, 08:20 PM | #6 | |
Rep 1,341
Drives: 2013 M5 SSII
05-21-2013, 08:48 PM | #7 | |
Rep 602
05-21-2013, 10:00 PM | #8 |
Rep 567
it happens in MDM too. it happens period with this car.
especially if your slowly maneuvering through heavy traffic and you need to make a quick (very quick) lane change, quickly jab the accelerator its BOG CITY for a good second. except you dont "have" a second and in these situations the car can be quite clumsy and flat footed. unless you're in 1st gear. and even then if you're stationary a quick pulse of the accelerator yields nothing but a slight rise of the rpm guage, the speedo does nothing. im hoping downpipes may solve (or at least lessen) this pathetic aspect of the f10. these are times i miss the e60 v10 |
05-21-2013, 10:42 PM | #9 |
Rep 444
Yea I hear you guys but the thing that happened to me today was like the car was just completely gone it was like zero life in the car, no skid, no traction control take over... That's what scares me cuz I was turning into on coming traffic and the car was coming pretty quick but I got an m5 so I thought I could leap ahead pretty quickly but the car completely died on me and i was royally fucked but it kicked back in about 5 seconds later thank god the car stopped. This is what's scaring me about this car, is this normal? I know there was some recall with some oil valve or something, I could be totally wrong but I don't know if this is what's wrong with the car.
05-22-2013, 12:59 AM | #10 |
Rep 1,583
How were you driving before that?? Maybe if you were driving relaxed the computer learned and was adjusting to your driving style then when you punched it it was so out of the norm from your previous driving style it took the computer a few seconds to adjust??? Happens to me at times to a degree. If all else fails down shift a couple gears and hit it. If it still does it then that might be something to have checked out.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
05-22-2013, 05:32 AM | #11 | |
Rep 1,027
This happened multiple times also on my wife's 2011 X5 and when it got to 47k we traded it for a X5 5.0 hoping the V-8s would not do this................ |
05-22-2013, 09:22 AM | #12 |
Rep 1,341
5 seconds...really? That I have not experienced.
I've seen 1-2 seconds max when punching it on wet pavement.
05-22-2013, 11:01 AM | #13 | ||
Rep 444
05-22-2013, 11:04 AM | #14 |
Rep 354
interesting ...
05-22-2013, 11:06 AM | #15 |
Rep 1,489
No power at all...I'd say something is definitely awry. Every once in a while I get a bit of a lag in full nanny mode, but it is non-existant in MDM with throttle set to Sport or Sport+. I'd get it checked.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black Last edited by M54ccibo; 05-22-2013 at 01:06 PM.. |
05-22-2013, 11:46 AM | #16 |
Rep 1,622
Next time keep the throttle steady and take notice to the dash. If its the DSC intervening:
1. You will feel the car accelerate down immediately and then slowly accelerate up to match your throttle position. 2. You will notice a DSC light flicker on the dash. You have to realize this car has a ton of toque available at around 1,500rpm. You can't just stomp on the gas to change lanes (especially when roads are wet).. by doing so you are relying on the cars systems to drive for you. If you did this with all systems disengaged, the car would kick sideways. If you don't notice 1 & 2 above, then I would suggest you bring the car to your dealer as this seems like a problem that needs to be investigated and fixed.
05-22-2013, 12:35 PM | #17 | |
Rep 571
05-23-2013, 02:22 PM | #18 |
Rep 1,917
It's called Drive by Wire technology. Putting it in sport mode will help some. What we need is a Sprintbooster for our cars. It worked well on my E60 M5.
Matt
