08-10-2016, 12:24 PM | #1 |
Rep 612
JB4+BCM advice
I have a full ECU tune and love it but wondering if adding the jb4 adds any additional value? Can someone shed some light on what additional features or power the jb4+BCM would give on top of my ECU tune?
Thanks everyone |
08-10-2016, 02:08 PM | #3 |
Hide! My wife's coming!
812
Rep 2,816
Youll want a backend tune that's to support the JB4/BCM. Adding the JB4/BCM and using the map settings can/may do more harm than good to your car.
FSociety3812.50 |
08-11-2016, 06:11 PM | #4 | |
Joint Chiefs of Staff
24198
Rep 190,805
Adding the Jb4 without adjusting the map might not give you much
08-17-2016, 05:53 PM | #5 |
Rep 2,062
It's my understanding that tuning has advanced enough on the S63TU engine that the JB4/BCM stack, other than logging, is pretty much obsolete now. Guys are running 700-800 with only flash tunes and stand-alone meth kits, no?
FSociety3812.50 |
08-17-2016, 05:59 PM | #6 |
24198
Rep 190,805
All the world records for this car have a JB4
08-17-2016, 06:21 PM | #8 | |
Rep 715
I believe max boost with a flash tune is 22.?psi. So with JB4 and BCM you can increase boost past 22psi is my understanding + you get increased logging capability.
08-17-2016, 08:19 PM | #10 | |
4918
Rep 115,980
08-17-2016, 09:59 PM | #11 |
Rep 2,039
Mike, I'm going to assume one, if not 2, things:
-you have an ownership interest in BMS -the margins on JB4/BCM are juicy Neither is a bad thing, I just notice you focus solely on the benefits and none of the challenges. |
08-17-2016, 11:46 PM | #12 |
Rep 135
Drives: 2015 M6 GC
True! But I think he is right to do so as to keep the playing field level, as they both have value and it ultimately boils down to what the owner/driver is looking to accomplish.
08-17-2016, 11:59 PM | #13 |
Rep 2,039
I own JB4 BCM and know its limitations especially the JB4 Connect Bluetooth device. But that device is not made by BMS.
08-18-2016, 11:17 AM | #14 | |
4918
Rep 115,980
Mike |
08-19-2016, 11:42 AM | #15 |
Rep 2,062
What are the devices limitations? I've only got the general idea of what the JB4 does but haven't gotten into specifics until now since it was just finally released for the S63.
08-19-2016, 12:13 PM | #16 | |
Rep 2,039
ECU tune is the way to go because you are changing values (reprogramming) vs. JB4 is sending modified signals to a stock ecu. It is hard for JB4 to stay consistent because the stock ecu adapts to normal, non-tuned, driving whereas a flash tune your ECU is always ready to put down the power. JB4 is great for people that want more than 700whp because it can control the amount of boost. It also works for meth and boost by gear (if your into launching or 1/4). These are just my views, please correct any inaccuracies |
08-19-2016, 09:09 PM | #17 |
Rep 788
^^^ weird, my car runs consitantly in map 1, 2 and on map 3 with meth. Solid times and results. Only time power delievery ever changes is when traction control is on fully or in MDM mode and traction changes this causes a very notiable change in performance which A/ you want and B/ you would get with a flsh or OEM.
08-19-2016, 11:08 PM | #18 | |
Rep 2,062
I've got a tune done by Halim, and while I completely understand why, but he's not investing a kit lot of time into my S63 platform since the S55 and S63TU are far more popular. I've been looking forward to the JB4/BCM for the benefits of logging and pushing boost past normal tuning levels that are tune limited still for my platform. I know the S63 can't be pushed as hard as the S63TU, but the added 4psi from my tune has already gotten old :-) I agree that piggybacks are kind of a bandaid fix, but I'm far more limited in options at this time. |
08-20-2016, 12:02 PM | #19 | |
4918
Rep 115,980
Edit I think I know what is set wrong based on your post. Update to the latest firmware and then set the future use d setting for slower canbus speed. I'd bet $5 that fixes your problem. Some cars need the slower canbus speed or logging and tuning cycles on and off randomly. Mike Last edited by Mike@N54Tuning.com; 08-20-2016 at 01:08 PM.. |
TheHouseWon644.00 |
08-20-2016, 02:04 PM | #20 | |
Rep 2,039
Looking at BPM as the front runner Thanks |
08-20-2016, 02:23 PM | #21 |
Rep 2,062
Is the Bluetooth inconsistent because of the above mentioned CANBUS speeds or is this only related to inconsistent performance? I don't wanna buy a half functioning Bluetooth dongle for $150 only to have it be a novelty item that never gets used.
08-20-2016, 07:37 PM | #22 | |
4918
Rep 115,980
FWIW as of a few months ago the slower speed setting is enabled by default on s63tu applications for those who don't run a detachable or JB4 mobile. Mike |
