      07-26-2018, 12:36 PM   #1
hl0m4n
hl0m4n's Avatar
Question ► Exhaust Vacuum Hose Size
does anybody know the exhaust vacuum hose size?
will a 4.5mm metal BB or a 7/32” be sufficient for plugging it.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      07-26-2018, 01:17 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Use a golf T. That is the default
good luck
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      07-27-2018, 05:20 AM   #3
Craze
M4 shanked bolt works
      08-02-2018, 12:58 PM   #4
Soul Performance Products
Drives: F80 / 987.2 Cayman S
A golf tee will work in a pinch but if you're looking for the "correct" 1/8th barbed plug this is what we supply with our Resonated Muffler Bypass. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      10-20-2019, 12:51 PM   #5
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Is this still the recommended peice for closing the vacuum lines. Also do you have to take the bumper off to install them? I just looked under my car and can’t seem to find the lines
      10-21-2019, 07:27 AM   #6
core22
core22's Avatar
140
Drives: X3 M40i / 911 C4S
When I had my prior AWE exhaust installed (by AWE at their facility) the vacuum line was plugged and then tucked back under the bumper via tie wraps of some sort. I'd check but I'm now back to the stock CP setup.
Current:
2019 911 targa 4 | GT Silver Metallic
2019 X3 M40i | Glacier Silver
Past:
2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi
      05-29-2022, 05:17 AM   #7
kjdeion21
Drives: BMW F10 M5
2023 BMW X3M40i  [0.00]
2013 BMW M5  [0.00]
I had the same issue, you need to lay down under your diffuser with the top of your head facing front and your eyes looking up and then if you tilt your head up looking behind the bumper where the mufflers were you can take your hand and feel behind the bumper inside and there should be a little 1/8" vacuum line that is about 4-6" long.
2013 BMW F10 M5, Moonstone Metallic, 700whp, stage 2 tune, fully straight piped - catless downpipes - resonator delete and fabspeed muffler delete, cold air intake and many more cosmetic mods. | '92 525i (long gone) | '02 Dinan M5 (sadly gone) | '06 Dinan M3 (also sadly gone)
      05-29-2022, 05:19 AM   #8
kjdeion21
Drives: BMW F10 M5
2013 BMW M5  [0.00]
Exactly, I just found mine... question for you... mine were never capped and I was driving on it for about 6 months and now I have an issue with the boost on my car and they talked about vacuum hoses and boost leaks... long story the hose was not capped and I will be capping it now, will or should I have already had an issue way back when, or perhaps there was an issue all along and I did not know....
      05-29-2022, 05:20 AM   #9
kjdeion21
Drives: BMW F10 M5
2013 BMW M5  [0.00]
Your link is unavailable or the item is... see this:
https://www.amazon.com/Quickun-Plast...NrPXRydWU&th=1
