05-21-2022, 12:31 AM | #1 |
Rep 280
Leaky injectors?
So, I'm having a bit of a worrisome thought. I had originally made a post about my car running rough on idle at times and cold starts after cleaning my MAF sensors.
I recently had downpipes installed and ever since then, now my car stalls out on cold starts after the computer turns down the rpm for the cat-heating (Which I do not need anymore) As soon as the idle settles down on cold start, it starts surging then just stalls out. Which is starting to worry me because I don't have a tell-tell sign of what is going on. I do not wanna be dealing with a leaking injector without knowing since I daily the car. I had originally gotten a code of the car running to rich "11811 Mixture Control 2, across banks mixture too rich" I had cleared it and it hasnt come back since, but still, the car on cold starts has been acting very very weird Once it is warmed up I don't really notice an issue, it seems to pull great and doesn't surge at all. No check engine lights on either. I am lost as to what could be going on, I also tried unplugging MAF's while the engine was running to see if anything would act up but it kept idling like normal, which I'm sure doesn't always rule out that the MAF's are bad as the car can still run without properly working MAF's. So i am lost on what could be going on |
05-21-2022, 12:33 AM | #2 |
Rep 280
To add to the post, once it stalls out once, I start it back up and it runs fine, it's just that initial 1-2 seconds after the RPM settles from the cold start
05-21-2022, 11:34 AM | #3 |
Rep 242
ISTA can check for leaky injectors if you suspect that but in my opinion I would say O2 sensor on Bank 2.
BTW did you replace the gaskets when you installed the DP? HFM disconnected will cause the car to go into open loop regardless of the reading from other sensors hence the normal idle but if you suspect that, switch bank 1 to bank 2 and vice versa and see if the code moves to bank 1 |
05-21-2022, 11:56 AM | #4 |
Rep 538
Could be O2 sensors. Did you hit them when they were removed or put back on? They're pretty fragile so you have to be super careful with them.
Also check all your connections to the ecu to ensure they're tight. People (myself included) have had all sorts of erratic problems due to loose connections. |
05-21-2022, 12:24 PM | #5 |
Rep 432
Mine was doing the exact same thing after I had my downpipes, tune, plugs, etc. installed. Pretty annoying because I could never let the car warm up without sitting in it and feathering the throttle. Never did this on my previous m6 with the same mods so I was dumbfounded. No codes ever thrown, though. I ended up thinking it was a spark plug issue and welp, it was. Just got my car back from another shop last week and they said my plugs were gapped incorrectly and over torqued. New plugs are in gapped to .020” with no issues since.
05-22-2022, 11:18 PM | #6 | |
Rep 280
But definitely the first thing im going to do is change my maf sensors because all these issues started as soon as I touched them. |
05-23-2022, 03:20 AM | #7 |
Rep 477
i had this code before and it was leaky injector, be careful if leaky injector dont drive the car.
05-23-2022, 02:42 PM | #8 |
Rep 319
alot of leaky injector talk going around but no action.
smooth running test in ISTA. Find out real quick. If you dont have ISTA, get it.
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock |
05-23-2022, 02:44 PM | #9 |
Rep 280
05-23-2022, 05:07 PM | #10 |
Rep 648
05-23-2022, 09:57 PM | #11 |
Rep 319
Injector solenoid leak test is in the misfire detection module. I just found it again. I have to find it every time I look for it lol..
Oh its a process... I have all the files at work. Maybe I can look tomorrow. You will want to dedicate a laptop to it. |
fstm5145.50 |
