03-08-2018, 12:54 PM | #1 |
Rep 210
HELP - Rear Clunk Noise
Hey, having a difficult time identifying the source of my problem and could use some help. I am hearing a "clunk or thud noise" from the rear of the car that happens sporadically and only occurs when the car shifts its weight (front to back or left- to-right or right-to-left).
The clunk noise happens - again only occasionally - when moving forward from a dead stop or when doing a moderate turn through a roundabout for instance. I've had my M5's shocks and springs replaced awhile back under the SIB that was issued. That was more of a harsh feel and noise when going over bumps. This was entirely different from this. The service technician inspected the car and saw some metal shavings near the differential and replaced the bushings. Although this seemed to help the problem it still happens from time-to-time. It's quite annoying as it's very audible. Anyone else have something like this? By the way, my car is slightly modified pushing close to 650 whp. Thoughts? |
03-09-2018, 11:29 AM | #3 |
1087
Rep 1,968
Possibly your diff mount is giving out...
BeachM5nster273.50 |
03-09-2018, 11:55 AM | #4 |
Rep 210
Thanks for the feedback! I suspect that what might be going on. I will report back after another attempt to resolve it. Have a great weekend!
And looking forward to hearing more about your crazy M5. Would love to see you offer a "built package" for the M5. |
03-11-2018, 09:20 AM | #6 |
Rep 547
I think I might be experiencing something similar. After a drive, when I come home to park the car, I stop, put it in reverse, front wheels turned a bit and if I hit the throttle a bit harder to get the car going back in motion I hear a kinda "snap" metal sound under the car around the rear...doesn't happen all the time though. Seems I can replicate the sound mostly when parking, reversing specifically and when I hit the throttle faster. Snaps once and then no more.
2016 BMW M5 MCB/Full Silverstone - "Maureena"
2013 BMW M3 E92 DCT - "Brynhildr" (Sold) 2012 Audi S4 B8 6MT - "BlackBird" (Sold) |
03-13-2018, 11:21 AM | #7 | |
Rep 210
Yes, your description of a metal "snapping" sound is more accurate. It's almost like there is tension that builds up and then releases (like snapping your fingers) from time to time especially with sudden weight changes. BTW, I had the diff mount / bushings replaced in the rear and, although it seemed to help, it hasn't resolved the issue 100%. |
03-13-2018, 01:17 PM | #8 |
Rep 547
^ Exactly, sounds like we have the same issue and good point to mention it happens when there is a weight change. Just hope its not the DCT
Advantage87.00 |
03-13-2018, 01:48 PM | #9 |
Rep 228
http://f10.m5post.com/forums/showthread.php?t=843819
SIB is attached. Let me know if this fixes your problem! |
03-13-2018, 04:57 PM | #10 | |
Rep 210
03-13-2018, 04:58 PM | #11 |
Rep 210
03-14-2018, 06:29 AM | #12 |
Rep 547
All stock.
03-14-2018, 09:05 AM | #13 |
Rep 210
03-15-2018, 01:18 AM | #15 |
Rep 1,124
From full stop turn your steering wheel start either left or right for 360 turn than step on a gas pedal (moderate speed). Perform this action in both directions with someone observing rear wheel for a skip while you listen for a clanking noise inside. If both issues confirm; that’s your knuckle problem.
03-16-2018, 09:25 AM | #16 | |
Rep 210
03-16-2018, 09:28 AM | #17 |
Rep 210
03-18-2018, 07:28 PM | #18 | |
Rep 210
Thanks again. |
03-19-2018, 04:38 PM | #20 |
Rep 14
im having the issue from 0-30 i guess moving the car straight first, second gear from suspension but i dont know whats the part thats damaged it happened yesterday and when i go above 30 it goes away. turning right or left no sound just once moving the car straight.
HCP M5 F10
03-19-2018, 04:46 PM | #21 |
Rep 14
same sound but only straight and i think its from the right front wheel or left front im feeling it in drivers seat however my friend in passengers seat says its so clear.
HCP M5 F10
03-20-2018, 07:23 AM | #22 |
Rep 210
That sounds different than my issue. I am sure someone on this forumwill be able to diagnose it based on your video. You may want to post a separate thread.
