      03-04-2018, 11:44 PM   #1
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Exhaust Cut-Outs Install & Video
I find the stock competition exhaust paired with catless DP's to be a very good mix of civility (cruising / idle) and some aggressiveness under WOT. However, the stock system has some limitations:
1. The X-pipe is restrictive
2. The muffler itself is slightly restrictive under very heavy flow
In my view the stock system is more than capable of 800hp, but tends to falter beyond that when trying to extract the maximum out of this platform.
I decided on a set of dual 3" QTP cutouts. Bought four 3-bolt flanges and had the cutouts mounted just prior to the resonators in the front section. The picture illustrates the position - its effectively like a straight-shot from the DP... down the front section and then straight out. No curves other than the initial turn-down from the DP's.
My car is generally louder than a comparable ZCP with catless DP's given the manifolds, turbo etc. flow a lot more. But when open, its just insane. At high RPM's its a level of ferociousness I have never felt/heard before.
The system seals very well - no leaks at all. The switch is mounted in the little cubby above the driver left-knee. Simple install (once the hardware is welded and mounted). I just tapped power from the cigarette lighter source so all power wiring is inside the vehicle.
m5 guy1691.50
M4RAUDR248.00
      03-05-2018, 03:59 AM   #2
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
great idea, must try
      03-05-2018, 08:33 AM   #3
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
Cutouts
High quality workmanship and an excellent mod. This is also on my list of mods.
2021 M340i
2020 X3 M40i - her car
      03-05-2018, 08:44 AM   #4
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
That will turn some heads at the 1/2 mile! Even before the spectators see the MPH you turn at the end of the run! Well done.
      03-05-2018, 10:43 AM   #5
allmotor_2000
1087
Thx - came out pretty clean. Ran all the external wiring under the under-body heat shields so it’s tucked away
      03-05-2018, 06:31 PM   #6
steeve13m
no more drone from 1k-2k rpm? or helmholtz pipes needed?
      03-05-2018, 07:06 PM   #7
allmotor_2000
1087
Lol.. I get seat vibrators now...
      03-05-2018, 09:40 PM   #8
josec70
josec70's Avatar
Very cool
      01-24-2022, 07:45 PM   #9
WindUp
Drives: BMW M235i
Can you tell me what parts you purchased to make this work? I'd like to order them and have my local exhaust shop weld it together. Thanks in advance!
      01-28-2022, 02:25 PM   #10
etnsandman
Drives: 2015 M5 Competition
Could you link the video? I'm very interested in hearing this setup
1320racer135.00
