      05-18-2019, 02:44 AM   #1
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
Meth install
I’m thinking of challenging this myself
I’ve been looking at the AEM kit and it seems simple enough.. just have to get the starting point correct and nozzle size which from abit of research I should be on the right path with that
I’m not going to run anything to fancy with jb4 or aquamist etc as I’m not planning on tuning for meth so if there is a failure on the kit everything should be fine as I’m just using it for cooling and my tune won’t rely on it
Anyone have any tips or should I take it to the shop 😂 if I do it myself I save around £1200 and looking at the aem instructions it seems simple
https://www.roadraceengineering.com/...kit-manual.htm
      05-18-2019, 12:58 PM   #2
Pikey Motorsports
Drives: M5
Also is a solenoid a must
      05-19-2019, 06:02 AM   #3
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I have the snow performance stage 3 kit. Super easy to install and I can help you set it up. Installation you can do your self. Pm me if you need help.
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
      05-19-2019, 08:54 AM   #4
OneExtra
OneExtra's Avatar
Drives: None
Do it and then show me the performance
Ps you need new brakes
