      03-20-2022, 11:15 PM   #1
M5addicted
M5addicted's Avatar
Drives: BMW M5
Hey, I'm new on forum, please help, i tried almost everything. Well the issue is when accelerating hard , pedal to the floor ( DSC OFF ) 1st gear start spinning wheels, when changes to 2nd gear power cut off, drops to about 2k RPM, loss of power ( 4k miles on new engine replaced, spark plugs, ignition coils, HPFP, MAF sensors, Injectors, air filters, Oil radiator, O2 sensors ) all changed! Did stage2, thought gonna fix the problem still, even the car drives like stock ** ( stock 7.69 kph 100-200, st2 ~ 7.5 kph 100-200 ) checked logs with tuner, said it looks good. No codes, no CEL , been at couple shops they don't know *May be someone had same problem ? Soon will upload the video.
My last log 3rd gear
https://www.autotuner-tool.com/en/lo...165bad039d6a3c
      03-20-2022, 11:20 PM   #2
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Are your spark plugs gapped correctly?
      03-20-2022, 11:23 PM   #3
M5addicted
M5addicted's Avatar
Drives: BMW M5
Didn't gapped them, like it is bosch bmw.
      03-20-2022, 11:33 PM   #4
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
You'll have this problem running stage 2 on stock gapped spark plugs. But it sounds like you had it happen before you did stage 2, so I'm not too sure.
Hopefully someone better versed in this will respond.
      03-21-2022, 12:07 AM   #5
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
+1 on what @M5_Raz said. Buy a step or two colder plugs and gap them to help improve spark. When you go WOT on factory plug at factory gap you are basically blowing the spark out. Hit up Burger Motor Sports, get their colder plugs, gapping tool and narrow walled socket. Check all the ground wire for contact as you button things back up.
If you have a wet/oiled filter cold air intake I would take the maf oil and spray them out really well with maf cleaner as the oil will skew the maf input. The double and triple check vacuum hoses and air intake as any unmetered air will cause problems
      03-21-2022, 05:08 AM   #6
M6Roar
Drives: '14 M6GC
I can see wheel spinning or bumpy road, TB taking dips, 2 knocks and cylinder 3 is taking a big dip.
First knock is fine but the 2nd isn't. what type of fuel are using and what type of fuel are you tuned for? also check your gap.
      03-21-2022, 05:19 AM   #7
M5addicted
M5addicted's Avatar
Drives: BMW M5
93 oct pump gas
      03-21-2022, 05:41 AM   #8
M6Roar
Drives: '14 M6GC
Originally Posted by M5addicted View Post
93 oct pump gas
Gap your plugs since OEM gap is 0.030 I think, and stage2 require 0.023" or 0.022". Had the same issue with my friends car resolved after gapping.
Don't forget to do a adaptation reset after gapping
Do another log and lets see. I hope the gap fixes it
      03-21-2022, 05:46 AM   #9
M5addicted
M5addicted's Avatar
Drives: BMW M5
93 oct pump gas
Thank you
      03-21-2022, 08:59 AM   #10
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
93 oct pump gas
If that doesn't work, check to ensure all your screws are tight and the connection on your DME's are snug. Had this same issue. During the shift from 2nd to 3rd, the jump pops the DME's out just enough for the connectors to slip out. When you let up off the throttle, they slip back in.
      04-29-2022, 07:23 PM   #11
Arwon
Drives: BMW M5 F10
HI , look I'm new here and others may be able to explain this, but the High pressure fuel drops off quite a lot from 4400rpm to 5800rpm, going down to 98 bar while the target setting is still about 198 bar.
I am looking into a similar problem with mine and will start running logs on mine in a similar manner.
Like i say this might be explainable with high fuel demand at those revs, but i doubt it.
