      02-15-2018, 09:30 AM   #1
Darkshear
Darkshear's Avatar
Drives: BSM 2019 M5 Comp
QQ: Anyone install their M Performance Electronic Wheel?
The instructions provided by BMW indicate TO "Connect branch A1 GN, using RT/BL cable to PIN 2 on A16*1B, using miniature connector G".
Except pin 2 isn't red/blue, it's green/red.
Anyone have an example they can speak towards?
2021 Brands Hatch Grey M5 Competition
      02-15-2018, 10:37 AM   #2
q8kamikaze
q8kamikaze's Avatar
Kuwait
103
Drives: 14 M5 F10 moonstone/SO
took mine to my mechanic and he did the job
the installation guide was a bit complicated
      02-16-2018, 03:44 AM   #3
V8munro
V8munro's Avatar
Drives: F10 M5 Sakhir Orange
Hi there i installed mine and also noticed this, despite the different colour i stuck with correct pin and it works fine
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
Darkshear154.00
      02-16-2018, 03:45 AM   #4
V8munro
V8munro's Avatar
Whats more annoying is the next pin is the colour they state lol
F10 M5 2013 Sakhir
Insta: Tommy_turb0
Darkshear154.00
      02-16-2018, 06:35 AM   #5
Darkshear
Darkshear's Avatar
YES lol agreed
Great thanks for the feedback!
      02-16-2018, 07:12 AM   #6
Darkshear
Darkshear's Avatar
So that's what I've done also, I figured it was far more likely the pin was right and the color was wrong.
I haven't had the car coded for the wheel yet though. Did you get yours coded right away? My wheel doest no power on, I assume because it hasn't been coded, but now the lane departure warning and blind spot assist are angry. Wondering if I grabbed the wrong wire somewhere else perhaps.
      02-16-2018, 03:19 PM   #7
V8munro
V8munro's Avatar
I did not need to code my wheel in for either car, first time i installed my wheel did not come on and i went straight down to that pin and switched to pin3 to see if it helped (it didnt) in the end it was the wiring in the actual wheel that i had plugged in incorrectly. Ive now had it in two f10s with no issues or coding only thing is ista software detects my heated wheel is no longer functioning. I do not have lane assist so cannot comment to much on that but id be looking at the black module in the wheel that clip in the bottom right side behind the airbag (4-5 o clock)
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-16-2018, 05:26 PM   #8
Darkshear
Darkshear's Avatar
Thanks man, looks like this is what happened to me as well. The connector for the control module under the airbag seemed to be proper, but turns out the colors aren't supposed to match up and I was effectively bypassing the control module.
Thanks for the tip! I have a working wheel now. Although I thought these needed to be programmed; apparently not.
      02-16-2018, 05:43 PM   #9
V8munro
V8munro's Avatar
Great news glad its all working
F10 M5 2013 Sakhir
Insta: Tommy_turb0
