12-18-2013, 11:55 AM | #1 |
Rep 709
2014 Competition Package M5 vs. 2014 M5 Base - layman's review
Hi All:
I had the chance over this past weekend to spend an extensive amount of time test driving 2 2014 M5's (street driving only). One with the competition package, and one without. It was the first time I've ever driven any flavor of M5, so I'm starting with a clean slate and no prior experiences to base my opinions on. I have no intentions of taking this vehicle to the track regularly, so that is my perspective as I was comparing these two vehicles. I wanted to share my thoughts and opinion in the hopes that it will help others who will use the M5 almost exclusively on the street decide if the package is worth it to them or not. As best I’ve gathered, the competition package makes the following modifications: - 15HP increase (no torque increase) - springs and damping rate increased by 20% - 15% stiffer anti-roll bars - 10mm lower ride height - Active M differential has a standalone control unit - M Dynamic mode allows a greater angle of slip - more direct steering - revised exhaust which opens baffles making it slightly louder at cruise and louder generally during acceleration. - specific 20" wheels - black chrome tailpipes Here's my opinions point by point after driving both cars with DSC on and all other settings set in the “middle” setting (usually “Sport”) except where noted below: 15HP increase (no torque increase) You're never going to notice this increase in power anywhere other than a track, and even then, a 3% horsepower increase is just not significant for most people to notice. Springs and damping rate increased by 20% The standard M5 is already pretty damn aggressive and given how well the standard 2014 M5 drives, I doubt there are many (any) folks who after a non-comp 2014 M5 test drive are screaming "this car needs stiffer springs and damper rates!" At a track, you'd probably appreciate this, but I’m not going to be at a track most of the time. On the street, you won't appreciate this at all because you’ll have dialed out the firmness in most cases with the adjustable dampers. The standard ride and handling are PLENTY capable and I personally found in my own test drive that the adjustable dampers set to Comfort or Sport mitigate the changes the Competition Package provides. In Sport Plus / most aggressive settings across the board, the standard M5 was pretty bone-jarring - certainly confidence inspiring. The comp package incrementally more so, but again, only at a track would anyone even be in an environment where they would appreciate this delta. 15% stiffer anti-roll bars - While the test drive included a good mix of canyon roads and freeway driving, again, the standard M5 (no comp package) was plenty capable and I couldn’t push the car on a test drive to the limits where this increased stiffness would be noticeable/appreciated. Both cars were 100% confidence-inspiring. 10mm lower ride height Track enthusiasts will care about this a bit. People who think 1cm is noticeable in the looks department will care a bit. Most people couldn’t care less about a centimeter drop. Active M differential has a standalone control unit I saw this in the literature for the comp package. I’m sure it excites someone. This just goes back to BMW’s “base” M5 being plenty capable. M Dynamic mode allows a greater angle of slip Again, my test drive was nowhere close to hitting the limits of either car. This feature isn’t really relevant to me even if I did. I will certainly be able to live with “a bit less slip allowance” on the non-comp M5. More direct steering This was most noticeable change on the comp package-equipped M5. There is more road feel through the wheel in the comp package car. There’s also more “agility” in the steering overall. This is probably the one biggest benefit the comp package provides. The standard car has a bit less road feel and a bit less agility (and it is really just an incremental improvement - we are talking nuances here). That said, those who have not yet driven a 2014 but have driven a 2013 or older F10 M5 should test drive the 2014. I read a lot of the complaints in the 2013 and older reviews that the steering wasn’t as direct as it could/should be. I would not be surprised if BMW generally improved the steering in 2014 in the non-comp cars as well. The steering in the “base” 2014 M5 was very, very good. It was incrementally better in the comp-package M5. Revised exhaust which opens baffles making it slightly louder at cruise and louder generally during acceleration. I’ll say this… If you want a generally louder exhaust, get a new exhaust aftermarket. The comp package cost is far too much for what to me was one of the two tangible benefits you’ll experience in day to day driving. The comp package car had a generally louder exhaust note and droned a bit more at cruise, so it’s definitely something you’ll want to spend quite a bit of time test driving to be sure you’re going to be OK not just with the sound at acceleration (which is fantastic), but also with hearing your exhaust system drone a bit more at cruise - ALL the time. That started to wear on me a bit to the point where when I drove the non-comp M5, I was quite happy that the standard exhaust note at cruise was a bit less obtrusive. Specific 20" wheels Personal taste. The comp package wheels do look better in person. In photos, not so much. The 343M wheels are a no-cost option on the comp package and I would definitely check that box. Those 343 wheels are gorgeous. Keep in mind the 343 wheels are a $1300 option on the non-comp car so the effective comp package cost is $6,000 if you were going to opt for 20” wheels anyway. Black chrome tailpipes Cosmetic. ———— To sum it up, as someone who is rarely going to experience the track/at-limit benefit the competition package provides, here is how much of the package I’ll never appreciate most of the time (and it may detract in some cases): - 15HP increase (won’t notice) - springs and damping rate increased by 20% (not something you'd notice on the street day to day and may be a net negative if you feel this makes the car’s ride too harsh) - 15% stiffer anti-roll bars (ditto although may be a net positive in day to day driving) - 1cm lower ride height (not noticeable) - Active M differential has a standalone control unit (couldn’t “feel” any difference on the street) - M Dynamic mode allows a greater angle of slip (limits not reached) - specific 20" wheels (I think the other standard and optional wheels look better) - black chrome tailpipes (cosmetic - either the bright chrome or black chrome look great) That leaves 2 remaining daily tangible benefits for $6,000 (assuming you’d opt for 20” wheels regardless, otherwise $7,300): - revised exhaust which opens baffles making it slightly louder at cruise and louder generally during acceleration. - more direct steering Is the competition package worth it to a driver that may rarely if ever take the M5 to the track? No. At the end of the day, the standard M5 is a fabulous baseline of performance. I want to use this car as a daily driver and maybe, someday, take it out for a spin or two on the track. This package is putting even more icing on a cake that really doesn’t need it. Is the competition package worth it if your M5 is seeing a good amount of track time? Up to you, but I would suggest that you spend the money on the ceramic brakes instead. If money isn’t a concern, just be sure that the 90% of the time you will be on the street and not on the track that you’ll be OK with stiffer, firmer and louder all the time vs. a baseline that’s already plenty stiff, plenty firm and slightly less loud. .02. Last edited by TonySCV; 12-19-2013 at 11:09 AM.. |
12-18-2013, 12:47 PM | #2 |
Rep 7,885
A very well written and well expressed write up.
I agree with all points. Like I have posted before, the Comp Pack is worth it if you intend on tracking the car more than 2 times a year, if not then it's all up to personal taste. If you really want the M601's, a lower ride height from the factory and more direct steering for every day use on the street, then the Comp Pack may be worth it to you as well. The funny part is that if the Comp Pack was available when the 2013's came out in the States, I would have gotten it. To each their own in the end.
12-18-2013, 02:23 PM | #4 |
BMW > Audi+ Merc. Simple math.
34
Rep 149
I drive a comp package, and I can honestly say that the exhaust is far from anything too noisy at crusing speed. Hell, my 120d give off more sound from engine and tires at cruising speed. The only time when the exhaust is very loud is when you are over 5000rpm going about, or downshifts at over 4000rpm. Other than that, it's pretty mellow.
I agree with the steering. I have not driven the standard M5, but damn the steering is nice in the M5 CP. Reminds me of the 1M, but with a bit more resistance when in Sport Plus mode. I love how they sorted out the road feel and such, despite the modern tech. The damping is just perfect in my mind. A bit too stiff for a family car maybe, when in comfort. You really feel everything bigger than a pebble. But hey, you just got yourself an M5 - get over it. It's supposed to be communicative with the driver. Also, i think the car gains plenty from having stiffer anti roll bars. I believe it offers great control of the body weight of the car, and it feels as firm as the 1M. I like that. However, the standard one could perhaps offer the same experience, without CP. The wheels are very good looking in person. MUCH better than the standard ones, and that's a scientific fact. They are also much lighter, since they are forged (and made in Italy). Combine that with the carbon ceramic brakes, and you have a winner in both performance and looks. Engine wise, the power gain is very small. I would agree it's probably not very noticeable. If you need power, get an aftermarket tune or something to really boost the power. Don't forged wider tires though, if you do. |
12-18-2013, 02:36 PM | #5 |
Knight Commander
559
Rep 5,948
Excellent review and captures exactly my perspective on the M5CP when I drove it back in August. I decided not to buy it for same reason as you. $6k is too much to pay for better steering and worse suspension. Exhaust was worthless to me since I'm an Eisenmann man.
2022 Mercedes-Benz EQS 580
12-18-2013, 02:48 PM | #6 |
Rep 4,220
Another thing steering me to the base and not the comp pack is the wheels. I don't care for the comp wheels and the 20" 343M wheels are fantastic.
12-18-2013, 05:45 PM | #7 | |
Rep 2,176
George |
12-18-2013, 10:42 PM | #8 |
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
This has been by far, one of the most helpful threads I've seen on this board. Thank you TonySCV. You answered a lot of lingering questions for me in this searching/buying process.
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
12-19-2013, 12:27 AM | #10 | |
Rep 1,576
12-19-2013, 04:47 AM | #12 | ||
Rep 2,176
12-19-2013, 05:14 AM | #13 |
1989
Rep 9,498
A very well written review and I mush agree with you Tony, I drew the same conclusions and thought (to me anyway) not worth the extra, I have added the CYBA Black Tips 90mm and Opened the Valves giving the same sound, which was enough for me. The STD Car as you say for road use is adequate.
12-19-2013, 05:17 AM | #14 |
1989
Rep 9,498
No they are not sorry they are CAST ask BMW.
12-19-2013, 07:01 AM | #16 |
10810
Rep 27,596
Nice write up. Im sure this will help out a lot of individuals.
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
12-19-2013, 09:22 AM | #17 |
Rep 1,440
Very nice write up! I sampled the comp pack M5 and liked it. It made everything seem sharper and tighter. The compromise in ride quality was what caught me by surprise. Agree that the most worth while item in the comp pack is the new steering rack. I would have it retrofitted on my pre-lci car in a heart beat if it's available. I will certainly be hounding the parts guy on this...
- Frozen Grey F10 M5 DCT
- Rosso Corsa 458 Speciale Sold - Frozen Grey E92 M3 Sold |
12-19-2013, 09:49 AM | #18 |
Rep 709
Good to hear . I was hoping to write this in such a way where it would help people interested in the package make a decision they felt good about based on their driving plans.
Thanks everyone for the kind words on the write-up. Glad you appreciated it. |
12-19-2013, 10:16 AM | #19 |
Rep 3,213
I agree with the other posts. Great write-up.
I have a MY13 M5 and am very disappointed with the steering, especially compared to the MY14 comp package car that I briefly drove. It seems that BMW improved the steering on the base M5 (maybe at the end of the MY13 run?) and notched it up more on the MY14 comp package car. My guess is that those of us with earlier-build MY13 cars will realize the biggest difference when comparing to the MY14 comp package cars.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche |
12-19-2013, 06:42 PM | #20 | |
Rep 1,440
12-19-2013, 09:22 PM | #21 | |
Rep 773
It's one of those options that when your spending $100k. Not sure $7k is really worth skimping on? |
