      07-23-2013, 08:40 PM   #1
Straight Dave
Straight Dave's Avatar
27
Drives: 2011.5 e92 m3
First tire change on the M5!
So just wanted to get everyone's view on the best tires and size to put on the m5! Not sure if I wanna jump up in size with my stock rims but I do love the PSS, Any other options that people like?
      07-23-2013, 10:13 PM   #2
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
I'd stick with the oem sizes if you're running the stock wheels. I think PSS's are the best tires out there.
      07-24-2013, 01:35 AM   #3
pochesq
pochesq's Avatar
Drives: 2013 M5
I agree with Grayblack and PSS is the way to go. I had Falkens and I didn't like them although they were briefly on my 21s. Look through the Board since you may qualify for the Michelin guarantee if your treadwear is less than a certain mileage.
      07-24-2013, 05:45 AM   #4
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
PSS is what all car forums have discovered and are running to. I agree.
      07-24-2013, 05:50 AM   #5
Netwon
Netwon's Avatar
2012 BMW M5  [0.00]
What mileage did you make it to before requiring new tires?
      07-24-2013, 07:38 AM   #6
JOHNBMWM5
JOHNBMWM5's Avatar
[/B]
+ 1
      07-24-2013, 06:46 PM   #7
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Agree 100% with Grayblack!
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
      07-25-2013, 01:14 AM   #8
runningthingz
runningthingz's Avatar
21
Drives: Frozen White M5
Totally agree!
      07-26-2013, 12:36 PM   #9
Niko1414
Drives: 720S, s550, S7, 997GT3RS
Waiting for the 305 PSS to hit the states...hopefully I can last
      07-26-2013, 01:01 PM   #10
Drives: Black M5
Any idea when Niko?? I'm in the same boat as you.
      07-26-2013, 01:37 PM   #11
pochesq
pochesq's Avatar
Drives: 2013 M5
Are you referring to the 305/30/20 Michelin Pilot Super Sport? They are available on tirerack. http://www.tirerack.com/tires/tires....SSXL&tab=Sizes
Current ///M: '13 F10 M5, Sapphire Black, Eisenmann Race Exhaust, CF Delete, H&R Sport Springs, iND Cosmetics, Escort 9500ix hardwired, 21" Vorsteiner VFF-103 w/Michelin PSS, RKP Front Lip, Challenge Rear Diffuser, M Illuminated Door Projectors, and LCI M Performance Black Grills
'15 i3 BEV
      07-26-2013, 03:06 PM   #12
Vic55
Vic55's Avatar
19355
Drives: 2023 BMW M8 Competition Coupe
305's on a 10 inch wheel is not optimal- it should be on an 11.... you guys can do it but its gonna have some carryover. And PSS's run square already on the sidewall.
But as Jose posted above they are here stateside.
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      07-26-2013, 07:34 PM   #13
ColdList
ColdList's Avatar
154
Drives: McLaren 675LT / C7 Z07
I think the recommended wheel size fro 305 PSS is 10"-11". I know in researching my new wheels the contact patch is the same in a 10.5" vs 11". You will get some sidewall stretch in the 11". I have them on my F10 in 21". I am not sure I would go 10" though. Prob. min. of 10.5" just because of the square sidewall.
      07-26-2013, 07:34 PM   #14
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
That's one good reason to go with the style 601M with the comp pak for new buyers -- 10.5" width will work better with a 305. Glad to see they finally made it over here.
What do you mean by "carryover"?
      07-27-2013, 07:49 PM   #15
Niko1414
Crap I thought the rims were 10.5.....Houston we have problem....won't the 305 tire stick out?. assuming that is what Vic meant by carryover
      07-30-2013, 07:06 AM   #16
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
I'm definitely looking at the 305 30 20 setup when I need new shoes for my stock 20x10 wheels. Doing the math, the 305 is .4" wider and .23" taller. In fact the 305 30s give you the same sidewall as the stock 265 35 20 front tires. The stock rear 295 30 20s are actually shorter than the stock front tires.
Vic has a good point (as usual) that it may not be optimal, however Micheline does rate the 305 30 for a 10" rim. All that said, I think the .2" (+.4" section width /2) on each side of the rim will offer slightly more rim protection from curbing while still providing a nice filled in yet square look. Also the extra tread width should help with traction.
Now I just need one of you brave souls to try the 305s out for me and post a review with pics!
      07-30-2013, 10:03 AM   #17
pochesq
pochesq's Avatar
Drives: 2013 M5
For those running 21s you can install Michelin PSS 265/30 and 305/25. That is what I'm running now with wheel sizes 9.5 and 10.5. You just need to make sure your offsets are just right.
      07-30-2013, 10:11 AM   #18
JOHNBMWM5
JOHNBMWM5's Avatar
Which are?.
      07-30-2013, 11:34 AM   #19
pochesq
pochesq's Avatar
Drives: 2013 M5
Originally Posted by johnbmw6 View Post
Which are?.
This is a "cut and paste" from the invoice I received from ADV1 to replace one rear wheel from an accident (not my fault) I got into recently. As you can see, unfortunately it does not include the offset information. If you have 21s or thinking of getting 21s, then I suggest you contact Ben @ Wheels Boutique. He'll know the correct offset!
Vehicle Year: 2013
Make: BMW
Model: M5
Wheel Style: ADV08
Configuration: Track Spec
SL Series Upgrade y/n: Y
Hardware spec / finish: Exposed
Brakes Oem / Aftermarket: OEM
Backpad Pocketing y/n:
Center Bore:
Notes: Replacement wheel for damaged rear wheel off original set. Submitted with picture
of damage to match fasteners and finish.
0.00 0.00
3 Piece Forged | Track Spec Contoured Profile | ADV08 SL | 21.0 X 10.5 1 2,400.00 2,400.00
Center disc finish: Brushed w/ Single Dark Tint w/ Clear 1 100.00 100.00
3 Piece Lip Finish: Polished Aluminum w/o Clearcoat 1 0.00 0.00
3 Piece Inner Finish: Standard Single Tone | gloss gunmetal 1 40.00 40.00
Center Cap: ADV.1 Standard Aluminum cap | Finished to match wheel 1 0.00 0.00
Ground shipping - Domestic 1 50.00 50.00
Engineering: Repeat File 3217W (Rear Wheel) 0.00 0.00
0.00 0.00
$2,590.00
$0.00
'15 i3 BEV
