      10-27-2014, 04:33 PM   #1
MarkFT
MarkFT's Avatar
128
Drives: BMW M3 (G80)
408m wheels for winter - need spacer?
Hello All,
I just picked up a lightly used 2013 M5, along with a square set of 408m 19" wheels with snows for winter use (from original owner of M5). Now, the tires are all 255 and the wheels are all 9x19 ET35. After doing some reading, it appears that these won't fit the rear wheels without a 10mm spacer - can anyone confirm this? Short of pulling the wheels off and trying myself, I haven't been able to confirm based on a search of the forum and online.
BMW M3 (G80)
Gone: 911 GTS, BMW 1M, E46 M3, X7 M50i, Porsche Cayenne GTS, X5M, M2CS, Cayman GT4 (981), Alfa Giulia QV, Carrera T, F80 M3 CS, Focus RS, M2 (OG), 14 E63S AMG wagon, M3 & M4 (F8X), X5 (F15 & E70), 335IS, VW Golf R (MK7), Audi SQ5, Cayman (987), M3 (E90), M5 MT (F10), A4 Avant (B8), S4 (B8), RS4 (B7), VW GTIs (MK2 to MK6)
      10-27-2014, 09:17 PM   #2
bronch
Waiting for the sun
bronch's Avatar
66
Drives: 2018 M240ix
Unless I don't understand ypur question, did you lower the car or have a higher sidewall on the tires? Now I'm new to the M5 having just ordered one, but, the 408M's are the OEM choice for the winter set up. You would not need spacers.
2012 E92 M3- Miss her.
2015 F10 M5- Land yacht, but miss her too!
2016 991.1 GT3- Woohoo!
2018 M240ix- Daily driver. Still Woohoo!
      10-27-2014, 09:32 PM   #3
MarkFT
MarkFT's Avatar
128
Everything is stock, but the problem is the stock wheel setup is staggered, so the fronts are ET32 and rears are ET25. So, if there are four ET32 wheels, I suspect there will be a problem with the rears rubbing on the brake callipers based on other posts. I hoped someone else who was running 408M's could let me know.
BMW M3 (G80)
      10-28-2014, 03:04 AM   #4
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
Everything is stock, but the problem is the wheels are staggered, so the fronts are ET32 and rears are ET25. So, if there are four ET32 wheels, I suspect there will be a problem with the rears rubbing on the brake callipers based on other posts. I hoped someone else who was running 408M's could let me know.
Yes you will need a spacer in the rear. It appears you have 4 front wheels. The advantage to that setup is you can rotate them front to rear without dismounting the tires thereby extending tread life and saving some money. The disadvantage is that you need to use a spacer in the rear. 7mm spacer would equal the stock ET25 rear offset. But a 10mm would be just fine. I actually used spacers with my 408m setup just to improve the look and stance, but it was not great because pushing the winter tires outward greatly increased the amount of road grime spit up on the side on the car in winter. Hope that helps.
Matt
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      10-28-2014, 08:53 AM   #5
MarkFT
MarkFT's Avatar
128
Matt
Great, thanks for the confirmation Matt. I don't mind that they are all fronts because, as you pointed out, this lets me rotate them without having to dismount. Now, I'll just have to find some 10mm spacers and extended lugs - any recommendations beyond the usual H&R or ECS Tuning models?
BMW M3 (G80)
      10-28-2014, 09:12 AM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
the official spec for the 408M
Front wheel: 19x9" ET32
Rear wheel: 19x9" ET25
There are a few threads in this forum under 'Winter wheels' which caution owners that to make sure the proper wheel is to put in to the proper place (if you reverse them on installation, esp. putting the rear to the front, then you are going to rub)
      10-28-2014, 09:18 AM   #7
MarkFT
MarkFT's Avatar
128
Thanks. I had perused most of the threads on winter wheels but could not find confirmation that people were using the 408M's as staggered or square - a lot of people seemed to indicate they were going square, but this seemed to pertain only to the tire size and not necessarily to the wheels.
BMW M3 (G80)
      10-28-2014, 10:23 AM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
there was one thread in particular (with pics) showing the owner put those wheels in reverse and after the advise given here to him, he had the shop put the correct wheels back to the proper place and the rubbing was no longer an issue. btw, it's a square setup and that's why it is highly recommended the owner to mark the wheels when putting them on.
See post #178 onwards ...
http://f10.m5post.com/forums/showthr...=723038&page=9
      10-28-2014, 11:21 AM   #9
mwlmd
mwlmd's Avatar
Matt
I used macht schnell spacers. They come with extended lugs. Ordered from IND.
CURRENT:
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      10-28-2014, 01:39 PM   #10
MarkFT
MarkFT's Avatar
128
Thanks, I had seen those mentioned a few times and they look like a good option.
BMW M3 (G80)
