10-30-2014, 11:05 AM | #1 |
Rep 228
Recall notice: retrofit heat protection mat to coolant lines
See pdf attached.
I have a MY2014 M5, and I just got this from local dealership as I am going for service. They said this was recently issued, and will be checked/fixed once I bring the car in. This is news to me, does anyone else MY14 M5 got this? any concerns?
"Speeding is like farting - you have to know when it’s inappropriate." - James May
10-30-2014, 11:14 AM | #3 | |
Rep 228
I thought maybe this is just for the M5/M6 turocharger issues..
10-30-2014, 11:36 AM | #4 |
Rep 1,837
Cause i had extensive leaking, so they did it awhile ago, but now they are doing it for everyone, even if there is no leak
10-30-2014, 02:22 PM | #6 |
Rep 4,721
I had the leak back last year and the correct fix was not what this TSB called for, it was fixed by putting sleeves over the tubing and using screws to tighten on the sleeves. The coolant pressure was too much for the ordinary factory clamp to hold on.
10-30-2014, 02:24 PM | #7 | |
Rep 228
10-30-2014, 02:31 PM | #8 |
Rep 4,721
I don't know.
Based on my experience, TCBMW tried to put in new clamps (jut like the factory) and they ran them for pressure testing and found they new ones did not hold (same result - failure with coolant leaking still). They then spent two days contacting Germany and see what the next fix and the result was the method I described. Afterwards, they did the full pressure test and the new sleeves/screws held with no issue. After having driven for another 1 year since, they fix held up very nicely. |
10-30-2014, 02:33 PM | #9 | |
Rep 228
Probably just let them do it and see..
10-30-2014, 02:39 PM | #11 |
Rep 4,721
well. You can check yours now and see if there are any greenish residual. If you do, you have a leak.
Don't ignore this as the coolant can enter into your engine and ... well, you don't want to know the end result, even though it's under warranty. |
10-30-2014, 04:44 PM | #12 |
David Dennis
Rep 24
Recall
Orich
If you don't currently have a leak, all they will do is fit the protective mats over the rubber unions, as it is the heat that is causing them to fail. My service advisor said that they now have a modified part if there are leaks found, however they still fit the heat mats. Hope that this helps. |
10-31-2014, 05:56 AM | #13 |
Rep 1,700
mine is booked in for this next week... hopefully there's no leakage!
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
11-01-2014, 06:34 AM | #14 |
Rep 228
Thanks all. Had it done at the dealer yesterday. No leak.
11-01-2014, 10:57 AM | #15 |
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
Hi just wondering where is it located? Is it behind the front light? Cant locate the piping..
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
11-01-2014, 01:22 PM | #16 | |
Rep 228
11-03-2014, 06:16 PM | #18 |
Rep 1,027
I had a coolant leak this summer and the car had to go in because it was overheating. This may have been the reason. They will be fixing it along with my hpfp tomorrow.
11-03-2014, 07:37 PM | #19 |
Rep 4,721
one of the first sign of the coolant leak is you will be getting (repeated) "Low coolant" message and even after you have topped it up, this message will come and go. Thus, you will have to check the coolant tubings to confirm.
11-03-2014, 07:58 PM | #20 |
Rep 305
I have a 14' but don't think I have received anything. I'm going to call in the morning to see if my VIN is included... I really don't like taking my car anywhere near the dealer...
11-03-2014, 09:00 PM | #21 |
Rep 4,220
11-04-2014, 12:12 AM | #22 |
Rep 107
Just sent the PDF to the dealer. My July 2012 built M5 is affected!
Porsche 991 911 Carrera S
BMW F06 M6 Gran Coupe BMW F15 X5 5.0 Xdrive M Sport. Mercedes C250 |
