      09-07-2017, 09:21 AM   #1
Rickzg
Drives: audi r8
Dyno Issue :(
Hi guys, I put my 2012 m5 on the dyno today and the ecu kept pulling the boost, it did not log an error as much on the computer but when diagnosed came up with '120908 Charge pressure control. switch off; pressure build-up block.
The car is stock except a cat back akra and a new fitted RK intake (cover around 40 miles of mild driving)
Anyone have any clues what the problem might be??
      09-07-2017, 02:03 PM   #2
Rickzg
Drives: audi r8
Well just heard back from the garage they said the car is very much under powered. It was only making 460bhp (crank) at 6k rpm then going into limp mode. The problem is there are no errors being displayed.
They have suggested they start stripping the engine and start looking for any possible leaks.
Has anyone had this issue before?
      09-07-2017, 02:41 PM   #3
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
There are a lot of knowledgeable people here, someone will shoot some info. Good luck and keep us posted.
Instagram MRBrandoe
      09-07-2017, 02:45 PM   #4
Rickzg
Drives: audi r8
I hope so buddy!
      09-07-2017, 04:14 PM   #5
apexlocator
Drives: 2014 M5
Are the vacuum lines for your exhaust reinstalled correctly (dont know if Akra has the exhaust valves), or at least plugged up?
2014 "AW/SO"me M5
Mission Performance/3.5 Bar
RK Autowerks/ CSF ICs
SSP Spec-R
KW V3/ Corsa Axle back
      09-07-2017, 11:34 PM   #6
Rickzg
Drives: audi r8
Hi bud the akra has been on for a couple of years and the vacuum lines have been connected correctly
The car has covered 30k miles on the spark plugs not sure if they require changing??
      09-08-2017, 05:33 AM   #7
M5_Brandoe
M5_Brandoe's Avatar
Sparks plugs and coil pack will result in misfires.
Instagram MRBrandoe
      09-08-2017, 06:52 AM   #8
Rickzg
Drives: audi r8
Well I was just notified that the wastegates on both turbo's are not functioning properly, and the tuner also put the latest software on the car to no avail. Any ideas on what could be happening?
      09-08-2017, 11:37 AM   #9
Rickzg
Drives: audi r8
Just been notified there is hardly any vacuum at all, some pressure sensors have now been ordered
      09-08-2017, 01:59 PM   #10
M5_Brandoe
M5_Brandoe's Avatar
Hopefully that is the issue. I'm not too familiar.
Instagram MRBrandoe
      09-08-2017, 03:16 PM   #11
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
I would left the car up and check those vacuum lines for the stock exhaust and have then re plugged. Also check plugs
      09-08-2017, 03:46 PM   #12
Rickzg
Drives: audi r8
I will check the vacuum lines myself tomorrow and chase them as far back as possible, but the weird thing is that there is not even enough vacuum in the system to open the exhaust flaps. The plugs will also be done while everything is off
      09-17-2017, 06:16 PM   #13
DaveCM5
Drives: 2014 M5 Sapphire Black
Does the car run normally on the street and only have the problem on the dyno?
      09-18-2017, 10:02 AM   #14
epiphanyray
Drives: 2003 E39 M5 + 2013 F10 M5
subscribed.
      09-28-2017, 01:57 PM   #15
Rickzg
Drives: audi r8
Hi guys, well I have the car back, seemed as though it needed the vacuum solenoids changed and i had leaky exhaust valves so these were plugged. The car seems to be all good now!
      09-28-2017, 04:27 PM   #16
apexlocator
Drives: 2014 M5
Glad to hear it wasnt a major issue...thanks for the followup.
      09-28-2017, 08:04 PM   #17
M5_Brandoe
M5_Brandoe's Avatar
Glad you were able to pin point. Simple fix, but a headache. You were lucky lol
Instagram MRBrandoe
