      06-19-2013, 10:44 AM   #1
runningthingz
runningthingz's Avatar
20
Drives: Frozen White M5
21" PSS tire pressure
What kind of tire pressure are you guys running in your 21" PSS?
      06-19-2013, 12:39 PM   #2
Poleposition
Poleposition's Avatar
Drives: very well
Ive run different pressures from 33 up to 40. I have found that running 36 all around is the most comfortable and wears evenly. Too much air and the tire will wear in the middle. Not enough air and the tire will wear on the outer edges. 36 seems to be just right. I check it weekly and adjust accordingly. Always check pressures when tires are cold. The coded option that displays tire pressure is very useful. Its very interesting to see the pressures and temps adjust as you drive.
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      06-19-2013, 11:38 PM   #3
PrimeTimeJohn
PrimeTimeJohn's Avatar
Drives: 2013 M5
I have 35-36psi in mine.
PrimeTimeJohn
      06-20-2013, 11:08 AM   #4
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
36 cold.
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
