      07-03-2019, 01:37 PM   #1
b21playa
Drives: LCI e60 535d msport
Drivetrain error
Hi all
Took the car out at lunch today and got an error in the idrive. Checked codes as they are as pictured
Any ideas
      07-03-2019, 01:49 PM   #2
aayaz
M Enthusiast
aayaz's Avatar
Drives: F10 Monte Carlo M5
I had similar codes pop up once a few months ago. I would clear all fault codes using your scanner, drive the car and see if the drivetrain malfunction error pops up again on the idrive system or the car goes into limp mode. If so, then you know what to address but sometimes it could just be a silly error code that isn't exactly true (like what happened to me).
      07-04-2019, 12:08 AM   #3
Boosted M5
Drives: F10 m5
When's the last time you replaced spark plugs? What is your current mileage? Running a tune?
      07-04-2019, 03:05 AM   #4
Were you gunning it when it came up or driving normally.
      07-04-2019, 04:17 AM   #5
b21playa
Hi
Plugs were apparently changed about 600miles who by previous owner. It’s running stock and has 83k on the car, 30k on the engine.
Thinking of swapping plugs out for peace of mind once I get my e39 out of the garage
      07-25-2019, 12:29 AM   #6
RG604
Drives: f10 m5
Originally Posted by b21playa View Post
Hi
any update on this?
IG: RacingGreed
      07-25-2019, 07:01 AM   #7
b21playa
Originally Posted by RG604 View Post
any update on this?
EML hasn't come back on and haven't had the chance to change plugs either yet.
      09-02-2019, 03:11 PM   #8
b21playa
Finally got around to changing all plugs and coil packs. Coil packs were original from 2013 - thought I might as well change while doing plugs.
Oil is next on the list
