03-08-2018, 10:46 AM | #1 |
Rep 382
Finally straight E85 support?
Looks like straight E85 has finally been tuned on the F80 M3 platform. Do you think it will be soon that it will also be an option on the F10 M5? I bet E85 would be a game changer for the F10 M5. Even more so then 93 plus methanol injection!
Thoughts? |
03-08-2018, 10:51 AM | #2 |
Rep 881
High pressure fuel pumps cannot keep up with full e85. Mission performance can tune for straight e85, but has to limit whp to around 600whp. If it were doable on stock HPFP, I would have done this long ago....
03-08-2018, 10:56 AM | #3 |
Rep 382
Would it be possible to upgrade the fuel pumps and then tune for straight E85 or would it still be better overall to do 93 plus methanol injection?
03-08-2018, 11:45 AM | #4 |
Rep 881
That's the question....who sells upgraded higher flowing fuel pumps?...no one AFAIK. All of these big HP builds all running stock HPFPs and supplementing with methanol.
03-08-2018, 11:49 AM | #5 |
1087
Rep 1,968
Not quite:
1. My cams are modified to add 30% lift to the HPFP... can run 800whp w/o meth 2. Working on upgraded HPFP... stay tuned |
03-08-2018, 11:51 AM | #6 |
Rep 382
03-08-2018, 12:24 PM | #7 |
Rep 881
schnell1982345.00 |
03-08-2018, 12:46 PM | #8 |
Member
28
Rep 41
Keep me posted! I believe I have same cams unless you had Steve do something to yours specifically. Break in is almost over what do you think is safe to run boost wise without meth?
03-08-2018, 03:28 PM | #9 |
1087
Rep 1,968
You have to log according to octane, boost etc. to determine what's best. There is no magic #.
03-08-2018, 03:29 PM | #10 |
1087
Rep 1,968
03-08-2018, 06:47 PM | #12 |
1087
Rep 1,968
Will probably cost $3-$4K with associated hardware and won’t guarantee it will work either. What if you need to swap cams... and that meant swapping heads.. you see where this goes!
03-13-2018, 07:32 PM | #13 |
Rep 402
whats the value to e85 on our cars? we already can significantly over power the stock rods, we already make too much torque, e85 will make it worse. I guess to avoid meth but even a pump 93 tune can really put a hurting on stock rods
03-15-2018, 06:58 PM | #15 |
1087
Rep 1,968
