      09-13-2014, 09:49 PM   #1
PetrolFumes
Drives: Raptor, GT3RS,E92 M3,X5M50i
KW coilover VS KW Sleeve over
Basically i am just looking to lower the car and get rid of body roll while keeping EDD. What are the pros and cons between the two?
      09-13-2014, 11:59 PM   #2
Fantasm
Algeria
39
Drives: SL63
Sleeve is only option to keep ED.
You don't need the full kit, its only for racing applications.
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
      09-14-2014, 10:09 PM   #3
PetrolFumes
Perfect. Thank you
      09-19-2014, 10:38 PM   #4
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Not exactly true. The standard V3 coilovers are designed for streetability, and are very comfortable.
Their ClubSport version are designed for racing.
Matt
      09-20-2014, 12:11 AM   #5
diononiz
diononiz's Avatar
Drives: 20 Porsche 911 Carrera S Cab
You should also consider the Dinan Coilovers and Sway bars. I have them and am very impressed with the ride quality vs handling balance. I have my car lowered about an inch.
20 Porsche 911 Carrera S Cab - Agate Gray
19 BMW X5 4.0Xdrive - White with Msport
19 Aston Martin Vantage - Magnetic Silver - Lemoned
16 Porsche 991 Turbo - White/Black - Gone but missed!
      09-24-2014, 09:21 PM   #6
SSR
SSR's Avatar
Drives: F10 m5
I am very happy with KW sleeves I had H&R and the ride was terrible.
      10-04-2014, 10:20 AM   #7
runningthingz
runningthingz's Avatar
20
Drives: Frozen White M5
I have the V3's and the ride quality is so smooth. Can't believe I didn't do this upgrade sooner.
      10-04-2014, 01:15 PM   #8
Fantasm
Algeria
39
Drives: SL63
The v3 has way more configurable options than needed for street.
v3 is for the track.
If you want a coilover for the street (but you lose Electronic Dampers), you can get v1 or v2 or H.A.S.
You will almost never use all the configurable options in the v3 for the street.
People just automatically "think" the v3 though because its the model most spouted off.
I wonder how many people even know there is V1, V2 and the differences between the versions.
      10-05-2014, 12:31 AM   #9
PetrolFumes
Also considern comp springs that are for sale here over sleeve over kit
      10-07-2014, 10:16 PM   #10
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
There is no V1 or V2 for F10M5 or M6
KW HAS
KW V3
KW Clubsport
Are the only available suspensions for F10M5 from KW
The V3 is dual adjustable = compression and rebound in a single shock which is the most common for street tuner applications.
The Clubsport is 3-way which is more for race track.
The KW V3 is the best suspension mod for this car.
Superior handling with better comfort then OE or anything else.
If you want to keep the OE EDC shocks (which are subpar to the V3) you can get the KW HAS or Dinan Spring Kits.
Then there are the Comp Springs, which lower a bit but don't do much else.
And last but definitely least, you can ruin your handling and ride comfort with H&R springs (might as well keep it OE)
      10-08-2014, 07:13 AM   #11
Fantasm
Algeria
39
Drives: SL63
KW HAS
KW V3
KW Clubsport
Ahhh... I wasnt aware that some applications don't have v1 and v2 editions!
Still, I think the H.A.S. kit is more than enough for 99% of M5 end-users.
Even for me and I drive it hard and have comp pack, I'm pretty sure I would be good to go with just the HAS kit to replace comp pack components.
      10-08-2014, 12:01 PM   #12
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
With both the Dinan and the KW HAS kit... you are essentially replacing the springs only with the addition of height adjustment. So basically, a glorified spring kit. And we all know how well that worked out with the H&R spring kit
Shocks are a vital component to a car's handling characteristics, more so then springs when it comes to improving comfort and handling ability. You can only soften or harden the ride comfort with springs or degrade the handling with harder springs (as is the case w the H&R spring kit on these cars.
However, you can vastly improve ride comfort and handling abilities by replacing the shocks on any car with better, more sophisticated ones.
There is a reason race cars have $15k shocks and not just springs replaced with OE shocks.
The F10M5 suffers from a heavy chassis (4300 lbs.) and a long wheelbase (good for high speed stability).... the best mods for this car are better shocks and sways to help the car be more nimble and feel lighter. The KW V3 kit accomplishes this very well on this car and makes this car feel 800#s lighter and provides more agile handling. That is worth $3500 over the $1200 spring kit to me all day. And makes the car's power more usable and the overall car experience more fun.
      10-08-2014, 09:13 PM   #13
SSR
SSR's Avatar
Drives: F10 m5
100% with Mastek!
BTW H&R suck !!!!!
      10-09-2014, 09:41 AM   #14
shahano
Does anyone have the part number for the competition package springs and sways?
      10-17-2014, 02:42 PM   #15
mcvaughan
mcvaughan's Avatar
KW V3 FTW
Matt
      11-15-2014, 01:05 PM   #16
M5LA
Drives: 13 F10 M5 Alpine White - sold
Just installed Dinan swaybars and KW V3 coilover last night. Can someone let me know the best setting for the V3 for compression and rebound? I do not track and like a smoother ride. Thanks.
      11-15-2014, 09:17 PM   #17
Mrbig
Drives: 15 M3
From what I have read the KW sleeve kit is the best for the ride and proper height adjustment and keeps factory suspension settings am i correct ?
      11-17-2014, 09:39 PM   #18
M5LA
Can someone with KW coilover let me know what your settings are? Mastek?
Thanks.
      11-18-2014, 02:59 AM   #19
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
Thanks.
Sorry, havent checked this thread for a while... u should have PMd me.
I would have to check again. But i sent my settings to McVaughan and have cleaned out my PM box since. So i dont know off hand.
      11-18-2014, 04:25 PM   #20
M5LA
Got your reply. Will adjust them tomorrow. Thanks.
      11-18-2014, 06:15 PM   #21
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
McVaughan was kind enough to send me what i sent him months ago
FRONT
6 = Compression
6 = clicks from hardest on rebound
REAR
5 = Compression
? = Rebound (could not get to it, behind rear parcel speaker?)
For ride height i HIGHLY recommend you get a corner balance done at the same time.
You can decide on a ride height then.
Contact Toan or Gary @ Platte Forme in El Monte, CA to setup an appointment.
(626) 768-0005
Also, the lower you go, the more negative camber (premature inside tire wear).
There is no front camber adjustment on these cars.
      11-18-2014, 08:46 PM   #22
GotE46M
GotE46M's Avatar
58
Drives: Few M cars.
Have the sleeve over kit and could not be happier with the ride quality!
