      12-19-2017, 05:29 PM   #1
steeve13m
Just installed the front Powerflex Upper Thrust Arm Inner Bushings!
I removed the worthless "DINAN Tension Strut Ball Joint Kit" which made crazy crackling noise on slow turns and just installed the street version Powerflex bushings with the offset version ....HUGE difference in handling compared to oem and Dinan....car feels planted on turns finally...highly recommended
https://powerflexusa.com/f10m5f06f13...ngsoffset.aspx
      12-19-2017, 05:39 PM   #2
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
How easy to swap?
      12-19-2017, 07:11 PM   #3
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Nice! Didn't even know Powerflex made bushings for our cars yet. Currently having the Dinan balls installed so if they don't work out I'll know where to go. Thanks!
      12-20-2017, 02:22 PM   #4
steeve13m
Originally Posted by allmotor_2000 View Post
How easy to swap?
Had mechanic do it but you need the tools and skills to press the oem bushings out... maybe 4hrs work....plus alignment
      12-22-2017, 10:18 AM   #5
M5 TT
Scotland
169
Drives: F90 M5
see you get street or race options. what did you go for. what's the difference?
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S
      12-22-2017, 10:36 AM   #6
Drives: Black M5
Very very interesting. I have the Dinan Monoballs installed and they are fantastic. No problems whatsoever. I have about 7-8k miles on them now. The steering was definitely improved with them.
      12-22-2017, 02:17 PM   #7
steeve13m
I guess the Dinans were defective ...loud noises and zero improvement....Race might be too stiff and prone to noises too so street is a major improvement....finally feel safe going 180+ MPH on the highway
      12-28-2017, 01:26 PM   #8
Drives: Black M5
Indeed, we don't want any uncertainty whilst traveling at 180mph+ like M5 drivers should be doing.
      12-28-2017, 02:32 PM   #9
steeve13m
correct handling confidence is key at that speed....any other tips to firm up the suspension is welcomed;
so far;
- new front oem bmw arms @ 50k miles
- Powerflex street thrust bushing
- Dinan front/rear sway bars
- AC schnitzer lowering springs
- Performance spec alignment
- what else?
      12-28-2017, 06:41 PM   #10
Goranot
Drives: Bmw m5
so far;
- what else?
So far;
-Dinan Front/Rear sway bars
-AC Schnitzer lowering springs
Will power flex street thrust bushings make noticble difference over oem?
Performance spec alignment ? What changes compared to standard wheel alignment
Thanks
      12-28-2017, 10:20 PM   #11
steeve13m
Originally Posted by Goranot View Post
So far;
Thanks
Yes powerflex bushings make big difference and it also increases positive caster in alignment......performance alignment meaning increasing negative camber etc
      06-27-2018, 06:16 PM   #12
Spinny02
Spinny02's Avatar
Still liking them? Thinking about getting a set.
      06-29-2018, 06:46 AM   #13
TopEnd
Drives: 2014 BMW M6 Gran Coupe
likewise
      07-04-2018, 01:26 AM   #14
azndrunk74
Drives: Frozen Black F10 M5
Anyone else have feedback on this?
      07-05-2018, 08:23 AM   #15
steeve13m
Yes its a must for this car....you will notice improvement in handling...use the street version
      07-21-2018, 11:33 AM   #16
Goranot
Drives: Bmw m5
Unfortunately street version isn’t available anymore in UK..
According to Powerflex they found them lacking over Oem hence combined both street and race into one .
Not sure how much truth in above as was contemplating replacing mine to street version but due to them being discontinued very cautious as race might be too harsh for normal street use..
Any advise appreciated
