ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      11-01-2023, 04:49 PM   #1
NORAGRETS
NORAGRETS's Avatar
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Anyone done this mod to convert to the B58 coils?
Kits and coils going for $500 ish.
Supposedly 2.3x the spark as the S55 coils, can anyone attest to a difference in performance?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021
      11-01-2023, 04:50 PM   #2
DeTh
DeTh's Avatar
335
Drives: F82 M4 BSM
2017 BMW M4  [0.00]
2016 BMW M4  [10.00]
Subbed, want to hear about performance gains
17' F82 BSM - Current Built Motor/PS2+
16' F82 Silverstone - Totaled FBO
NORAGRETS444.00
      11-01-2023, 06:20 PM   #3
Dsmdrew
Drives: Go5
I have a kit but haven't installed it yet. I asked bm3 if adjusting the dwel is really needed they said no. I was worried about running them without the dwel changed
NORAGRETS444.00
      11-01-2023, 06:21 PM   #4
NORAGRETS
NORAGRETS's Avatar
I would adjust it it doesn't make sense not to why wouldn't you?
      11-01-2023, 07:08 PM   #5
chetrickerman
ECUTek Master Tuner
chetrickerman's Avatar
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Yes, I did it and its worth it. Less ignition timing corrections overall.
Torque is a measure of an engine's ability to do work; Power is the rate at which work is done
NORAGRETS444.00
Hotflare188.50
      11-02-2023, 12:11 AM   #6
Hotflare
Hotflare's Avatar
Drives: 2018 YMB M3 Comp
2018 BMW M3  [9.50]
Night and day
NORAGRETS444.00
      11-02-2023, 08:25 AM   #7
b_w.
From what I recall reading no returning is required but for best results have them installed prior to a custom tune.
      11-02-2023, 03:16 PM   #8
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
[QUOTE=NORAGRETS;30617995]Anyone done this mod to convert to the B58 coils that are on the G80's? Kits and coils go for $500 ish. Supposedly 2.3x the spark as the S55 coils, can anyone attest to a difference in performance?
Wouldn't that be S58 coils?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
NORAGRETS444.00
      11-02-2023, 05:16 PM   #9
NORAGRETS
NORAGRETS's Avatar
[QUOTE=RoundelM3;30620693]
Not G80 idk why I said that.
      11-02-2023, 06:21 PM   #10
chetrickerman
ECUTek Master Tuner
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Correct, you dont need to retune for the new coils. The B58 ignition coil dwell time is very close to the same as the S55.
      11-02-2023, 06:58 PM   #11
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
Does anybody understand the technical reason coils would help with timing corrections? I understand how they help misfire (more energy needed to jump the gap with higher boost and e-content). But timing corrections should in response to knock/ping/pre-ignition. How would a more powerful coil reduce knock/pings/pre-ignition?
I'm wondering if different coils have different amount of spark latency (time between being told to fire and actually firing), so potentially impacting your actual spark timing, despite running the same timing map? It would make sense with different windings you get different inductance values, and therefore different latency? I've researched it a bit and found some clues suggesting this, but haven't found anything definitive.
      11-02-2023, 07:18 PM   #12
chetrickerman
ECUTek Master Tuner
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Its pretty simple, improved flame propagation and combustion stability
No
n8dgr84173.50
      11-02-2023, 08:27 PM   #13
n8dgr84
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Drives: M2C - 6MT - Flex Fuel
No
Got any logs to show the difference? Is it mostly around peak combustion pressures?
      11-03-2023, 09:32 AM   #14
wheela
wheela's Avatar
No
Thanks for your response. I did some more searching to try and understand the "why" behind this, and finally came across some intersting research articles related to this. In this article, they're reasearching fuel economy in a natural gas (NG) spark ignition engine,
but the focus is ignition of the combustible mixture based on spark energy, so directly analogous. They're basically saying that with higher spark energy, the bigger spark kernel reduces the ignition delay, and increases the initial flame propagation speed during ignition. So it's improving flame propagation and combustion stability by "kick starting" (my own words) the flame propagation out from the ignition point (the spark kernal) through the mixture in the cylinder - this I can get my head around.
https://www.sciencedirect.com/scienc...60544221024920
n8dgr84173.50
NORAGRETS444.00
      11-03-2023, 09:36 AM   #15
wheela
wheela's Avatar
So I'll be adding b58 coils to my build list
NORAGRETS444.00
      11-03-2023, 10:43 AM   #16
n8dgr84
174
Based on my logs, I don't think upgrading ignition helps significantly until you upgrade turbos. It adds weight, so you have to consider that, as well, if you're a road racer and care about handling.
NORAGRETS444.00
      11-03-2023, 11:04 AM   #17
NORAGRETS
NORAGRETS's Avatar
What is it; 2lbs?
ck_M363.00
      11-03-2023, 04:17 PM   #18
Dsmdrew
Drives: Go5
I want to see logs! I'll install mine after I see some logs
NORAGRETS444.00
      11-03-2023, 05:46 PM   #19
wheela
wheela's Avatar
You have the kit, right? Throw her on and take some logs! You can do it!!
NORAGRETS444.00
DThr33635.50
      03-26-2024, 10:55 PM   #20
n8dgr84
174
Here is my review with datalog
https://f87.bimmerpost.com/forums/sh....php?t=2092743
      03-26-2024, 11:26 PM   #21
b_w.
I have not moved my car from the garage yet but it idles nice and smooth with the b58 coils
NORAGRETS444.00
      03-27-2024, 09:02 AM   #22
NORAGRETS
NORAGRETS's Avatar
What kit are you running?
Coils?
Sparks?
What’s year is your car?
I’m beginning to wonder if production date has anything to do with the ability to run the coil swap without issues….
f80post
