European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      03-17-2024, 05:19 PM   #1
MotoGPWannaBe
MotoGPWannaBe's Avatar
EU6 or EU5 for stock turbos on 93
My f80 is at 112K miles and I’m planning to replace the injectors and coils as preventative maintenance. Not planning on upgrading turbos until the stock ones fail. Considering EU5 injectors since I’m already doing the job. I already have BM3 stage 2 and the flex fuel kit but I run 93 about 99% of the time because I’m scared of it making my injectors stick. So my question is should I stick with EU6 injectors from FCP or go with EU5?
Also, is there any reason for me to switch to B58 coils now that BM3 has a that capability in their tunes?
Please share from experience only. Thanks in advance.
      03-17-2024, 09:10 PM   #2
rudebwoi
Drives: 17 F82 6MT ZCP Mineral White
I am running eu5 on stock turbos with bm3, no problem.
      03-18-2024, 08:41 AM   #3
Jmk508
Drives: M4
Are the eu5 injectors less prone to get stuck?
      03-20-2024, 05:08 PM   #4
kamilbaran
kamilbaran's Avatar
138
Drives: '18 Yas Marina M3, '17 M240i
Try nostrum injectors
      03-20-2024, 06:49 PM   #5
b_w.
Don't have to flow as close to max to make power so less stress.
      03-21-2024, 03:45 PM   #6
n8dgr84
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Drives: M2C - 6MT - Flex Fuel
Stock EU6 injectors have plenty of flow capacity for stock turbos, especially on 93.
I would stick with them because of the specific spray pattern for the S55 unless you need more flow. If that was the case then I'd go with Nostrum Stage 2 because they are EU6 (Euro 6 emissions) spray pattern.
I am putting in B58 coils this weekend so will let you know if it's worth it.
      03-21-2024, 03:50 PM   #7
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
I'm excited to hear your impressions of the b58 coils once they're in
      03-22-2024, 10:50 AM   #8
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
I ran E60 for years, stock injectors. never had any issues
https://x-ph.com/sale/
Phone number 702-494-9435
      03-22-2024, 04:23 PM   #9
RAT3DM
Mod Junkie
RAT3DM's Avatar
Drives: F82 M4, E36 M3
  [0.00]
No actually the opposite...more prone.
      03-23-2024, 11:56 AM   #10
n8dgr84
174
Well, it starts easier on E60 but sadly the weather is not good enough to put any power down. All stock BM3 settings. Nexsys kit was easy to install. Only issue was the hard plastic channel that houses the stock coil wiring had to go for clearance on #6. The "heads" on these coils are massive. Anyway I wrapped the loose wires with 5/8" split loom to protect them from heat. More to come in a separate thread.
      03-25-2024, 03:57 PM   #11
MotoGPWannaBe
Good afternoon,
Ok, since I’m planning to upgrade turbos within the next couple years and fcp has the replacement program I went ahead and ordered the EU5 part # 13647599876. Those are the Bosch injectors that everyone seems to be buying from FCP.
The shop I use who has a couple 1,000 hp f80s is telling me that they seem to have no issues with the genuine BMW injectors but those cost more than 3x the Bosch. So I’m planning on trying the Bosch and if I have issue, returning to FCP.
Also ordered the b58 coils from eldor and the nexsys adapter kit. Hopefully fitment isn’t too difficult.
Scheduled to have everything installed and coded on April 8th so if anyone thinks there’s a difference between the Bosch and expensive AF bmw 13647599876 injectors, please let me know.
I’m praying that the shops experience is based on the power level/e85/etc. and is anecdotal to my situation running 93 at 500 wheel give or take.
Thanks for the feedback.
      04-07-2024, 02:00 PM   #12
MotoGPWannaBe
Tomorrow is the big day,
Installing everything and coding via ista+ and checking the BM3 boxes for EU5/B58 coils on the OTS stage 2 flex fuel tune.
Notes:
- Fuel injectors from FCP part number the same as genuine BMW but made in Turkey stamp.
- B58 coils from FCP that stated Eldor did not say Eldor on the box but instead a different brand name.
- Nexsys kit looks good and appears to have everything needed connectors and resized boots.
- Changing spark plugs and charge pipe o rings while we’re in there.
Ultimately, I’m feeling a little like a guinea pig and have been having paranoid thoughts about not buying the 300 dollar each genuine injectors but they just aren’t in my budget anyhow. Hopefully I’m surprised to find out they are exactly the same as the 90 dollar Bosch injectors I purchased.
I’ll probably wait until I’ve been using everything for some months before posting my feedback to avoid a premature assessment.
      04-08-2024, 12:29 AM   #13
djpeetur
djpeetur's Avatar
Drives: F80
Running eu5 on OTS map was the best decision ever for me. Feels like a brand new car. Best of luck. I have 100k on my car and the injector was life changing.
      04-08-2024, 07:56 AM   #14
Jbonly21
Jbonly21's Avatar
Drives: Bmw 15 F80, 2011 X5 35i, E46 M
Are you saying you are running ea5 on OTS and not a custom tune? Every where I read said you need a custom tune to dial it in.
https://youtube.com/user/Jbonly21
      04-08-2024, 01:27 PM   #15
n8dgr84
174
There is no E85 OTS tune.
      04-08-2024, 01:35 PM   #16
Jbonly21
Jbonly21's Avatar
It said Euro 5 injectors not E85.
n8dgr84173.50
      04-09-2024, 12:21 AM   #17
djpeetur
djpeetur's Avatar
Drives: F80
I have ps2 bolt on. Check the eu5 on bootmod OTS map. Was life changing. My car never ran better than it is now. I’m more concerned about reliability than going really fast. Switch to stock KN filter. No misfire. Start up with no sputtering. Just clean 93 burning really well with the ps2.
Jbonly211081.50
      04-11-2024, 10:29 AM   #18
n8dgr84
174
Jbonly21 It's also recommended to code the new injectors in ISTA+ ($20) for the exact flow rates of each injector. But no, you don't need a custom tune for just an injector swap.
https://youtu.be/ErTLV0NqIOM?si=XPewAHlgg-JH4Sya
Jbonly211081.50
      04-11-2024, 12:41 PM   #19
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
A question I have when I see people talking about eu5 or eu6 is emissions. Bm3 let's you change the injector, but this doesn't let you pass obd2 emissions.
So are people who use eu5 Injectors living in no emissions states/counties?
      04-11-2024, 02:48 PM   #20
Jbonly21
Jbonly21's Avatar
I saw that, thanks. My injectors should be here next week.
[QUOTE="SYT_Shadow;31065054"]A question I have when I see people talking about eu5 or eu6 is emissions. Bm3 let's you change the injector, but this doesn't let you pass obd2 emissions.
I will let you know in 2 years!
n8dgr84173.50
SYT_Shadow11490.00
      04-25-2024, 07:14 AM   #21
Jbonly21
Jbonly21's Avatar
Instelled my injectors over the weekend.
f80post
