proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      03-24-2024, 03:49 PM   #1
Bmweth24
Drives: BMW F32
Concerns buying a used f82
I went to inspect the car and it had oil leaking also ran it for codes. Transmission was clear but the engine had some misfires I will attached the screenshots but other than an oil leaks would it be worth it to buy it? It has about 100k miles and about to go into service (idk if they’re going to fix it)
      03-24-2024, 05:00 PM   #2
headstart101
Drives: 2016 MG M4
Buying that car would not be worth it unless it’s a good deal even with a bad motor.
      03-24-2024, 05:03 PM   #3
Bmweth24
Drives: BMW F32
What’s a good deal for you?
      03-24-2024, 05:19 PM   #4
headstart101
Drives: 2016 MG M4
With 100k miles and clean title, no more than $31K.
      03-24-2024, 05:33 PM   #5
Bmweth24
Drives: BMW F32
That’s what I was thinking. Even with the misfire?
      03-24-2024, 06:04 PM   #6
headstart101
Drives: 2016 MG M4
With the misfire you could still be rolling the dice because there could be other issues that are not obvious yet. If the only issue is the misfire and the engine runes fine when warm, I’ll say go for it but just be aware, you could be buying a problem with no end in sight.
      03-24-2024, 06:05 PM   #7
cF82
Drives: 2015 M4
I would definitely check the oil pan gasket as that’s a major issue with the oil leakage. And make sure there’s no bad scuffs to the oil cooler.
      03-24-2024, 06:24 PM   #8
TSL
Drives: BMW M4
2015 BMW M4  [0.00]
31K is still high, I wouldn’t pay over 27. Friend of mine bought a clean title ‘15 F82 with 55K miles and a 6MT for 32K. Decently optioned as well. He bought his last week.
      03-24-2024, 07:42 PM   #9
b_w.
I would be concerned about the low oil code. Doesn't take much to starve the engine of oil.
      03-24-2024, 11:15 PM   #10
headstart101
Drives: 2016 MG M4
Clean title? Which state?
      03-24-2024, 11:16 PM   #11
TSL
Drives: BMW M4
2015 BMW M4  [0.00]
Jersey
      03-25-2024, 01:21 AM   #12
headstart101
Drives: 2016 MG M4
Jersey
I’m Ca so prices are a little higher. High mileage clean title cars are going in the high 30’s here.
      03-25-2024, 10:36 AM   #13
Bmweth24
Drives: BMW F32
I saw oil leaking on the valve cover and oil filter housing
f80post
