      08-20-2014, 09:35 PM   #1
SSR
SSR's Avatar
Drives: F10 m5
M1-M2 mode
Hello I have configured M1 and M2 buttons in the st wheel but I need to know this,if I down shift or up shift with the st wheel paddles the M1 or M2 modes go and then I can make shifts with the paddles only.
It is possible to use a M mode and shift with the st paddles ?
Sure it is possible but I don't know how!
      08-20-2014, 09:54 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
You have selected D(1,2,3) part of Driving mode for M1 & M2 button and that's why when you use paddles the M indicator gets disappeared. Simply select S(1,2,3) instead for M1/M2
      08-20-2014, 10:13 PM   #3
SSR
SSR's Avatar
Drives: F10 m5
Wow correct I will test sure that makes sense!!! THANKS
      08-21-2014, 02:29 AM   #4
shahano
you can also put the car in the setting that you wish, then hold on M1 or M2 to directly presave it instead of going through the whole menu..
      08-21-2014, 02:55 PM   #5
M5 RAG
Drives: SG + SO F10 M5
Interesting - didn't know this, thanks.
      08-21-2014, 03:15 PM   #6
Volum
Estonia
People, read your M5 manual.
      08-21-2014, 03:23 PM   #7
(H)
(H)'s Avatar
Drives: F80 M3 (after F10 M5 ;-)
Wish we had an M3 button ;-(
IG: hartmutkraft
FB: seventeenjewels
      08-21-2014, 07:42 PM   #8
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
We do it's called comfort and efficiency
      08-21-2014, 09:41 PM   #9
gmfive
gmfive's Avatar
Drives: 2014 F10 M5 AW
2014 M5  [0.00]
+1 for post of the day
Speaking for myself, it is hard to go to an m3. In the fewest possible words: it just doesn't feel as solid as an m5.
2014 AW F10 M5, mostly stock
