      12-03-2012, 11:46 PM   #1
rhogue
Drives: M5 Silverstone
Radiator fans
After every drive, the radiator fans remain on after the engine stops. It doesn't last long but is this normal? I can understand if it was really hot outside but given that it's winter, I'm surprise this is happening.
I called my local BMW dealer and they said this is normal. Anyone else experiencing this?
Thanks
      12-03-2012, 11:51 PM   #2
Niko1414
Drives: 720S, s550, S7, 997GT3RS
Happens all the time...very normal
      12-04-2012, 12:38 AM   #3
nugent
nugent's Avatar
Drives: f10 m5
i also Notice that the fans tend to stay on longer than I would expect.
      12-04-2012, 04:52 AM   #4
jmh
Internet Crash Test Dummy
jmh's Avatar
Cooling fans/water for the turbos
      12-04-2012, 08:59 AM   #5
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Interesting, is the car able to keep a circulating pump operating for turbo cooling even after the car is turned off? Is it possible that cooling might also be for the water cooled ECUs in the engine bay? This car is by FAR the most technically challenging piece I've ever owned, or will own in a month or two.
      12-04-2012, 09:06 AM   #6
rhogue
Thanks for the feedback!
      12-04-2012, 08:50 PM   #7
jmh
jmh's Avatar
The conventional coolant pump is driven by a belt and cannot be used for cooling the exhaust turbocharger after the engine has shutdown. For this reason there is an electic coolant pump, which works at a power of 20W. This is done by a seperate cooling circuit. This circuit can also be activated during engine operation, the electric coolant pump can be switched on taking into account the following factors:
- Coolant temperature at engine outlet
- Engine oil temperature
- Injected fuel quantity
The heat input into the engine is calculated thes values. The after-run of the electric coolant pump can last up to 30 minutes. To improve the cooling effect, the electric fan is activated and can for up to a max of 11 minutes.
There are two separate 50W cooling pumps for the DMEs (one for each bank)
      12-04-2012, 09:47 PM   #8
Used2be
Perennial PFC
Used2be's Avatar
Thanks for taking the time for your detailed explanation. I've learned something new and appreciate the effort.
