      11-29-2016, 10:45 AM   #23
BimmerRick89
PWRDBYM
BimmerRick89's Avatar
Drives: 20' M340i - 20' X7 M50i
Originally Posted by DATM3 View Post
Here is a little guide I just whipped up as I just recently installed a JB4 +BCM and Bluetooth connect kit on my M6. It took me about an hour to do it as I have done it about 3 times now. Let me know if you have any questions about it.
The wire for the obd can be tucked under the plastic covers where I have the line drawn.
UPDATE: Picture with the intake off.
I have to say this is one of the most informative pics for installing the BCM! Excellent job! I just did this on my M5 however, I used JB4 instructions from Terry (still pretty vague instructions, IMO, because lack of Pictures)...I wish I saw this post before doing the install!
I do have a question for when I have to remove for a dealer visit...did you not have to remove hose on the top of the IC? Also, I was happy to hear you were able to do this without having to remove the right 2 cooling lines (makes a huge mess)...was there still a decent amount of room?
      11-30-2016, 07:19 AM   #24
mjposner
mjposner's Avatar
895
Drives: 2020 Z4 40i
Replacement extended paddles? Thanks
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/
      11-30-2016, 02:14 PM   #25
allmotor_2000
1083
Drives: 2018 RS3, 991 Turbo
That sure looks like a picture of my engine bay... including the scuff marks on the charge pipes, color of meth lines etc.
      11-30-2016, 02:20 PM   #26
DATM3
DATM3's Avatar
Drives: Nissan GTR / F06 M6
Lol, i just googled S63tu and used the pictures on there for my write up. I haven't been back on these forums for a couple of months since I sold my M3 & M6 and picked up a GTR again. Are you still rolling everyone in the M5?
      10-29-2017, 11:23 AM   #27
M5averick
M5averick's Avatar
Drives: 2013 BMW M5
Originally Posted by TrevorM3 View Post
DME removal?
Its pretty easy. I have attached a little picture of what you need to remove to remove the DME's.
Basically remove the plastic Engine cover (just pull up it snaps off). Then remove those items in the picture I have the arrows to. The ECU assembly locks in similar to how the engine plastic cover is. You just pull it off the rubber grommet holes. Do the same for the other side.
Make sure you zip-tie those coolant lines up so it doesn't leak everywhere.
Thanks for that post, helped me pull the DME's out quickly and confidently. Very cool!
I was dreading it initially as my car is already tuned but I have to send the ECU's out again to have the cold start disabled.
One thing I did notice is the 2 torx screws pointed out in the picture on my car were actually a little larger than T20. I ended up grabbing a T27 bit and that worked but it may even be a touch larger than that bc it did move around a little bit. They weren't on that tight however so the T27 bit worked just fine.
Also, I just worked the clamped hoses down by the clamps on the 2 coolant lines from each of the ECU's with needle nose pliers. They are on pretty tight but the hoses ended up sliding down off the nipples with the clamps still on in about 20 seconds of elbow grease each. I'm reading that there is very little pressure is in those lines so I'm planning on just pushing them back on with the clamps still in tact when I get the ECU's back.
Thanks again for the picture.
2013 F10 M5 - AMS Catless Downpipes - MSR Intakes and Charge Pipes - SSP Spec R carbon clutch w/ baskets - Vorsteiner V-FF 105 20" forged rims - 315 Toyo R888Rs - AWE Diamond Black Touring exhaust - DME TUNING Stage 3 tune - Cold Start Delete - CF Rear Diffuser, and CF eyelids.
      11-30-2017, 01:38 AM   #28
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Anyone have a Turbo Swap DIY ? They're on the top so they cant be difficult, just having direct instructions would be very helpful.
2012 E92 M3
World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3
11.49 @ 121.54
10.38 @ 136.04
