      11-13-2016, 02:08 PM   #1
boots
Curve Thrasher
boots's Avatar
623
Map sensor diy
Does anyone know of a easy way to get to the map sensors so I can replace them.
Country run
      11-13-2016, 04:39 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Should be able to access them once you remove the intakes which is easy to do. Loosen the intake hoses, unbolt the one screw on each intakes box and pull them out. You should then able to see the map sensors on each side. Just disconnect the wire to it and again using a T20 or T25 torq bit, remove the two screws and pull it out.
#3 on the diagram. It's on each side of the intercoolers. Also circled in the picture.
      11-13-2016, 04:40 PM   #3
13M5F10
13M5F10's Avatar
Pictures attached
OneExtra810.50
      11-13-2016, 04:47 PM   #4
boots
Curve Thrasher
boots's Avatar
623
Thanks Raumy but that's not the one I'm talking about
      11-13-2016, 05:27 PM   #5
13M5F10
13M5F10's Avatar
Maybe MissionPerformance , BPMSport , or dmetuning can hint on how to access the other two. I can't seem to find a good diagram to show how to access them.
I thought you were talking about those sensors near the intercoolers.
      11-13-2016, 07:18 PM   #6
boots
Curve Thrasher
boots's Avatar
623
I have the diagram. Thanks.
      11-16-2016, 07:56 PM   #7
schnell1982
Drives: FAST
The MAP sensors in the intake manifold are not that easy to replace.
There is not a "short cut.
Erik @ Autohaus Frankfurt replaced mine and a few other M's I have seen there. Took him about 3 hours to replace all 4 map sensors.
      11-18-2016, 12:35 PM   #8
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
why are u guy changing the MAP sensor
      11-18-2016, 07:54 PM   #9
boots
Curve Thrasher
boots's Avatar
623
Thanks schnell1982. I did speak to eric.
Drm5. It's for more tune ability for diff files.
      11-19-2016, 01:43 PM   #10
Drm5
Puerto Rico
30
thx boot...!!! good luck
      11-20-2016, 02:55 AM   #11
boots
Curve Thrasher
boots's Avatar
623
Thanks drm5. Yes like everyone said its a pita. I hate to pay someone but it looks like I may have to go that route.
      11-20-2016, 09:18 AM   #12
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
For the bottom ones you have to pull the undercar covers, belly pan among other things. It's also on top of the intake manifolds and things are very tight down there...
      11-20-2016, 04:14 PM   #13
boots
Curve Thrasher
boots's Avatar
623
It's a f up situation then.
Hey Allmotor are you using any e85 w your car
      11-22-2016, 08:19 PM   #14
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Getting codes or just changing to be proactive?
      11-22-2016, 08:58 PM   #15
boots
Curve Thrasher
boots's Avatar
623
I want to stomp with the big dawgs James
m5james431.00
      11-23-2016, 01:59 AM   #16
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Epic pain to change them... unfortunately.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      11-23-2016, 02:29 AM   #17
black-n54
Drives: 335i E92
i've done this 3 times in the last 2 weeks, after some freak-out moments its OK
now I can do this work for 1 hour
      11-23-2016, 04:37 AM   #18
Halim@HCP
Denmark
721
Drives: BMW F80 M3
It's a PITA to change. Depends on size of forearms, I got cut bad lol. First time it took me 2.5 hours, now I can fix this up in around 45-60 minutes.
This is the correct picture, number 9 on this pic.
You don't need to change all 4, those located on intercoolers are 3.5 bar already, these located on intake manifolds are 2.5 bar.
      11-23-2016, 07:56 AM   #19
13M5F10
13M5F10's Avatar
Allows you to increase boost over the current stock limitations.
      11-23-2016, 11:46 AM   #20
boots
Curve Thrasher
boots's Avatar
623
For better tune ability
      12-06-2016, 01:26 PM   #21
m5james
m5james's Avatar
Halim/HCP told me this doesn't apply to the S63, so now I'm just that much more jealous of you S63TU guys
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      06-06-2017, 06:37 AM   #22
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Any new techniques or tricks? I plan on doing these this week.
