F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > BMW F30 on 20inch rims
Studio RSR
      05-21-2014, 04:38 PM   #1
DB328
Drives: 2013 F30 BMW 328i
Would 20'' rims fit on my 328i? Also what would be the major differences between 18'' and 20'' rims on the car?
      05-21-2014, 04:46 PM   #2
sonystyle02
sonystyle02's Avatar
Drives: 2016 AMG GTS
1) Yes.
2) Two inches.
In all seriousness, they'll fit just fine on a stock height car and you can even spare a mild drop before any cambering/tucking/pulling. In general, going with a larger diameter wheel means a heavier wheel and harsher ride (due to a thinner tire). I went from 19s to 20s myself due to the 20s filling out the F32 wheel well a bit better.
2016 AMG GT S Edition 1 | 2013 C63 AMG | 2014 435i | 2012 STI | 2007 S2000 | 2005 G35
Kid Red106.50
      05-21-2014, 04:50 PM   #3
DB328
I already have H&R Super Sport springs installed. So all ill need to do is install them and nothing else?
      05-21-2014, 05:11 PM   #4
sonystyle02
I'm not sure. Super Sports are supposed to have a 1.2" drop on them. Rubbing is a possibility depending on the offset and tire size.
      05-21-2014, 05:15 PM   #5
Jimminez
Jimminez's Avatar
Drives: 2014 F31 M-Sport
This.
More info on what the wheel and tire specs that you are thinking of would help to answer your question.
Martin
Past - F31 M Sport Estoril Blue - Thread - Pic
Current - 2021 Audi RS6 Avant
      05-21-2014, 06:00 PM   #6
dj_intrinsic
dj_intrinsic's Avatar
Drives: 23 G80 M3 6MT
Here ya go. You should be able to find different wheel specs throughout this thread.
http://www.f30post.com/forums/showthread.php?t=741571
2023 G80 MT / AW / Fjord Blue/Black | KW HAS | Apex VS5RS F:20x10+8 285/30-20 R:20x11+18 305/30-20 | Maxton Street Pro Splitter | OEM M3CS Grille | SST Valve Controller | CS Style Yellow DRL | MAD Non-Res Single Midpipe
Past: 2018 X3 M40i | 2016 M-Sport X1 | 2013 MT M-Sport 328i | 2021 Audi A6 Allroad
      05-24-2014, 03:28 PM   #7
vip
vip's Avatar
Drives: 2001 Alpine White M5
I am selling my 20" Ace Alloy Convex in Matte Black. See my sig below for specs.
sent from bimmerpost Android app
      05-25-2014, 08:48 PM   #8
AMJAM
AMJAM's Avatar
Drives: 2013 Alpine 328I MSport
They fit with no problems I have 20x8.5 front and 20x10 rear a seen in pic below
2013 Alpine White 328I M Sport ARRIVED
      05-25-2014, 10:31 PM   #9
GentlemanDriver
Drives: 2013 BMW 328i F30 M-Sport
Did you drop the car or is this stock?
      05-26-2014, 03:33 AM   #10
dtn
Prince of Zamunda
dtn's Avatar
Drives: '13 AW F30
http://f30.bimmerpost.com/forums/sho...d.php?t=909786
This will help too if you're thinking about 20s and a drop.
      05-26-2014, 05:19 PM   #11
Alex@TAG
Alex@TAG's Avatar
Drives: 16 RS7, 488 Spider, i3 REX, 57
I think the F30 NEEDS 20" wheels. but thats just me.
Here is one we recently did on H&R Springs and 20" Vossen CV7's. It just came out perfect!
      05-27-2014, 12:32 AM   #12
AMJAM
AMJAM's Avatar
Yeah it's lowered lol very lowered the rear tyre is under the guard and the front tread is under the guard as well. I wish BMW Brought their cars out this low
      05-27-2014, 09:10 AM   #13
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
Yup!
Yah I believe 20s fit just nicely. Here's mine lowered on coils.
      05-27-2014, 09:24 AM   #14
BeachsideF30
Drives: E90--> E92-->F30
Hell yea ridin on some twanky thangs.
      05-27-2014, 01:53 PM   #15
KennyHeartBMW
Drives: F30
Much harsher ride. but they fill up the wheels wheels pretty nice
      05-28-2014, 12:42 PM   #16
3onDubs
You live by the sword...
3onDubs's Avatar
216
Drives: M4
2007 328i  [0.00]
Originally Posted by Dippydo View Post
Yup!
Very nice...what wheels are those?
Would an h&r super sport drop be this low?
      05-28-2014, 01:12 PM   #17
Dippydo
2012 BMW  [1.00]
Well Kenny these ride a hell of a lot softer than the 17" runflats that come on the car.
      05-28-2014, 01:14 PM   #18
Dippydo
2012 BMW  [1.00]
Thanks. Vossen CV3's Not sure about the Supersports, I am running coils. Unfortunately I was so happy to get them put on, I forgot to take the beginning measurements to see how far I lowered it over stock.
      05-28-2014, 10:55 PM   #19
VELGEN WHEELS
VELGEN WHEELS's Avatar
234
Drives: BMW F82
20x9 & 20x10.5 Hubcentric / No Spacers / Use oem Lug Bolts
These cars are lowered on H&R SS
      05-29-2014, 12:07 PM   #20
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Just keep in mind that:
a. 20" wheels with very low-profile tires will be more likely to get damaged by potholes and other road hazards
b. They increase ride harshness because there's less sidewall to absorb bumps
c. The tires cost more to replace than 18" versions
d. They're heavier than 18" wheels (unless you buy super-expensive lightweight versions), which can have a negative effect on handling
Be really careful with wheel offsets, or the tires will rub the fenders/suspension.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      05-29-2014, 12:24 PM   #21
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
20s will definitely fit on the car, as long as you get the right width and offset for the wheels, and the right width and profile for the tires. You'll notice more feedback from the road with a set of 20s compared to 18s though.
      05-29-2014, 01:47 PM   #22
Dippydo
2012 BMW  [1.00]
Roundel you can have the same problems with 18s or 19s too with the wrong offsets. That will depend on the height. When you buy wheels you have to consider a lot of factors. Width, diameter, offset, and car's height. If you do not plan on lowering the car, chances of rubbing are zilt with 20s. Its when you start to lower the car is when you start to have issues and you will have them regardless of wheel size if you buy the wrong wheel.
For ride, that is personal opinion. I believe my 20s ride smoother and better than my 17 runflats. So again it will all depend on what you buy. There are some 20" tires that are softer than what I have and they ride very smooth and absorb bumps.
For price, yah of course the tires apples for apples will be more. But someone buying a BMW, especially a later model to new should not be too concerned about an extra $150-$200 per set. Hankook is one tire brand that is a great all around performance budget tire for around 220 each for a 275/30. I paid that for my Michellins for my Acura that were 17s.
Agree, they are heavier to some degree and like you pointed out depends on your price range. For having a negative effect on handling/performance, I would put money down that 99% of the public would not be able to tell the difference between an 18/19 or a 20 if they were blindfolded. Only experienced people that know cars, and there are a lot fewer than people think will be able to tell and even then if you shop for a good quality wheel, the effects will be minimal. Everyone claims they know, but in reality they have no clue. They just repeat the crap they read or hear from their friends without any real experience. Or perhaps they tried and did not do it right so they have a neg opinion.
I was so terrified to get 20s at first because when I had my 18s with a 50 series tire, I was going through 3-4 wheels a year literally. Been over a year now with my 20s and not one bend and have not had to replace one tire. Just like anything in life, you go the cheap route or the inexperienced route, you will get neg result.
328i, f30, rims
f30post
