      09-25-2018, 02:09 PM   #1
theinfamousdrew
I'm The Captain Now
theinfamousdrew's Avatar
501
Drives: X5M/X7
Excessive Washer Fluid Consumption
Hey guys,
I've noticed that I am constantly running out of windshield washer fluid.
About once a month or so and I don’t use it that often.
Over the weekend, I removed the wheel well to gain access to the system and checked for leaks. No leaks found and no residue found.
I have deactivated the headlight washers via coding long ago, so that’s not it.
I can’t stand them lol
Each time I get the low fluid warning, it always takes a full gallon to fill it up.
Has anyone else noticed excessive use of fluid?
One idea would be evaporation either from the poor seal on the cap or from the heat from the turbos at the nozzles .
Turn on. Tune in. Drop out.
IG: @InfamousCarGuy
      09-25-2018, 02:42 PM   #2
JtheW
Drives: 22 m850gc
I've had the same problem. I think its evaporating like you said. I've had to fill it up a bunch of times and I never really use the washers.
22 M850i gran coupe
      09-26-2018, 12:31 AM   #3
speedster77
speedster77's Avatar
32
Drives: E92 M3,E46 M3 6MT, 335d MSport
Definitely evaporation. I get it often too and almost never used it.
      09-26-2018, 05:42 AM   #4
core22
core22's Avatar
140
Drives: X3 M40i / 911 C4S
I'm currently in my 2nd F10 M5 and never experienced this, aside from a gallon over the winter months. Beyond that, nothing additional except fluid top off during service intervals.
Current:
2019 911 targa 4 | GT Silver Metallic
2019 X3 M40i | Glacier Silver
Past:
2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi
      09-26-2018, 05:52 PM   #5
TLK
TLK's Avatar
112
My '14 M5 also did this when I first got it last year.
The solution was to replace the reservoir cap. It snaps on/off and has a part number 61667238068. This is #11 in the diagram attached.
The seal is pretty flimsy and I think the engine heat kills it after a while allowing a lot of evaporation. The part is very inexpensive and no tools are needed to swap it.
      09-30-2018, 04:47 AM   #6
theinfamousdrew
I'm The Captain Now
501
Drives: X5M/X7
Thanks guys!
Installed a new washer cap yesterday and filled it back up. Hopefully this fixes it.
IG: @InfamousCarGuy
      10-03-2018, 03:30 AM   #7
AussieBob
Drives: 2010 F10 "M5"
Originally Posted by theinfamousdrew View Post
Thanks guys!
Let us know if this has also fixed your fluid loss issue. I've just ordered three of the filler pipe covers, I figure I'll need another few again in the future.
      01-22-2019, 11:43 AM   #8
theinfamousdrew
I'm The Captain Now
501
Drives: X5M/X7
Quick update on this....
This fixed the issue. I haven't filled it up since I replaced the cap.
Thank you again!!
IG: @InfamousCarGuy
      01-22-2019, 02:00 PM   #9
AddyDaddy
AddyDaddy's Avatar
Mine sprays out of the top and I have liquid underside of my hood when driven hard. Tech said its breather hole and not to worry about it?
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
