12-19-2017, 11:37 PM | #1 |
Rep 11,891
M Performance Steering Wheel help!
I bought a M6 with the v2 electronic steering wheel installed.
However, I cannot figure out how to actually use it. I'm able to muddle through the setup screens with the long and short presses of the buttons, but I don't know how to actually activate and use the wheel to have the shift lights come on, or to read the current oil/water temp, or the g-meter. Does anyone have an electronic or physical copy of the actual user manual you can send me? I found the install manual, but there's no actual instructions on it. It's frustrating to have such a cool wheel staring at you in the face everyday and not knowing how to use it. Thanks! Let me know. I'll take anything really, screenshot of a few pages in the manual, a video, a written explanation, a phone call...anything really!
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
12-20-2017, 10:06 AM | #3 |
Rep 11,891
12-20-2017, 02:22 PM | #4 |
Rep 139
I have the wheel also, hold both buttons to turn on, hold left to exit a menu, hold right to enter a menu and press left or right to scroll, you have the main menu that will show 4 icons from memory, first is dynamic/ economy stats, second icon is performance driving stats (oil/water temp, g force, timer and the third is race stats. The fourth menu is settings this is where you can set match the rpm to the car, set rom the lights flash at, celsius or Fahrenheit for temp and maybe some settings i have forgotten. I will try to find the pdf as well that explains it better (its at the back of the installation instructions) but hopefully what ive shared may help for now.
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth Insta: Tommy_turb0 |
12-20-2017, 02:26 PM | #5 |
Rep 139
Not tried sharing a photo before hopefully its clear enough
F10 M5 2013 Sakhir
Flying Ace4984.50 |
12-20-2017, 03:22 PM | #6 | |
Rep 11,891
That said, I was able to play around with the features. The only thing I'm confused about now is, what's the purpose in the settings menu of setting your G-Meter Threshold? Is it so that if you met the threshold, the wheel will display the metric? Else, it'll continue to show zero?
12-20-2017, 03:28 PM | #7 |
Rep 139
Ill check for you but i believe like you say its the threshold before it moves from 0. Mine is left at the default setting. I just changed temp to Celsius and rpm shift down to 6700
F10 M5 2013 Sakhir
Flying Ace4984.50 |
