09-04-2015, 11:55 PM | #1 |
Rep 806
Ran the ESS Tune Tonight
So I finally got out to the track tonight with the ESS Tune.
Also this was the fist time running the car with the MSR intake. Previous best was 11.56 @ 122.3 MPH and the DA was dreadfully over 4000. (BMS @ 3.0, Gruppe M and Exhaust Mods). Tonight first run 11.15 @ 126.4 MPH and DA was best I've ever seen in 10 years about 1440. On the second run the Trap Speed was up to 127.30. First launch was almost a clean run, little bit of slip. Second and third runs, the track had dropped below 10C and car spun bad. Plus I was babying the axles a bit and my burnout was probably a bit too light.
09-05-2015, 01:30 AM | #2 |
142
Rep 639
Great runs! What were your 60' times?
edit: thanks for adding the timeslip to the OP.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) Last edited by Lerxst M4; 09-05-2015 at 01:26 PM.. |
09-05-2015, 09:43 AM | #5 |
Rep 1,202
Nice times. You're transmission is slipping with a flash, exhaust (stock dp), and intake? I have a 2016 on the way and am looking to do the same mods, but am concerned about what the limits of the transmission are (been hearing a lot of different feedback) - maybe you could shed some light on that, thanks.
09-05-2015, 10:35 AM | #6 |
Rep 745
Drives: '14 M5 CP & '62 corvette
Very nice run. I'm gonna head back to the track maybe next month to see if I can improve on my time before I add a tune.
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors 1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i) |
09-05-2015, 10:58 AM | #7 | |
Rep 806
Others have already posted that with aggressive tunes/driving, the clutch will fail. My best 60' was 1.739. The other two runs, I spun so I won't even bother to post those times.
09-05-2015, 06:14 PM | #8 |
Rep 611
Very very nice 60', very nice temperature too. What DR are you using?
Did you launch it? If yes at which rpm? Last edited by Andym3100k; 09-05-2015 at 06:20 PM.. |
09-05-2015, 07:33 PM | #9 |
Rep 806
I am running a 19" Mickey Thompson 305/35
No LC. Just flooring it off idle, D3.
09-06-2015, 06:35 AM | #10 |
1087
Rep 1,968
That's great times! Man those MT's help - need a set.
You should hit 10's easy. Slap on the BMS and add +1.0psi and you should be there especially with the traction you have. I compared your timeslip to mine and I was 5.3s at the 330ft so you are definitely hooking! |
09-28-2015, 07:50 PM | #11 | |
Rep 85
09-28-2015, 08:03 PM | #12 | |
Rep 1,123
So your saying we can run the ESS tune with the bms box? |
09-29-2015, 07:20 PM | #13 | |
Rep 806
Thats what I've been wondering the last few days as well. I have a BMS and I'd like to upgrade it to a JB4 anyways for logging. Car is pretty nuts already, it would be nice to add some boost over say 4000 RPM. Car already has too much power below 4000.
10-01-2015, 03:03 PM | #15 | |
Rep 1,250
Drives: 20' X3M CP
with weather like this (43F) your car would run nasty.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
10-01-2015, 05:19 PM | #16 |
Rep 806
Track elevation is 2200ft.
Air sucks at the best of times. Normally around mid 3000's. Bad days well over 4000.
