      05-05-2018, 10:24 PM   #1
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
Done the ramair filter mod now have problems
Recently done the ramair intake mod which a lot of you guys have probably seen on the forum. The car was fine for a day or 2 untill I recently went out tonight for some harder driving..
Car was low on fuel and just as I was about to get to the fuel station I had restricted power flash up with drivetrain malfunction and misfires.. I turned the car off, fueled up and everything seemed fine.. so I done a few pulls and the cel flashed up and has stayed on for a few hours, car has full power and no drivetrain fault just a cel on
I'm guessing the intakes are causing this? I've recently done an exhaust mod which I opened up the rear muffler flaps and tied them open, I left all vac lines plugged in?
Thankyou
      05-05-2018, 10:48 PM   #2
MpowerMike
MpowerMike's Avatar
361
Drives: 2012 IB BMW M5
Clean your maf sensors, I had the same issue with bms intakes and removed them and put back oem boxes and no problems .
      05-06-2018, 04:23 AM   #3
Pikey Motorsports
Drives: M5
I read not to clean them on here so did you send the intake back
      05-06-2018, 06:34 AM   #4
MpowerMike
MpowerMike's Avatar
361
I had to clean mine because oil residue got in , my car would misfire and go in limo mode at high speeds 4th gear plus. Also I would have a rough idle.
      05-06-2018, 07:00 AM   #5
Pikey Motorsports
Drives: M5
Thanks for your help seems like people are having issues with some intakes on these cars
Did you revert back to stock or keep the BMS?
      05-06-2018, 09:24 AM   #6
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Cel will automatically turn off after a few cycles if there is nothing wrong
      05-06-2018, 10:39 AM   #7
apexlocator
Drives: 2014 M5
I thought those ramair filters were oil-less?
      05-06-2018, 12:19 PM   #8
TheHouseWon
644
Drives: 2013 M5
It has something to do with AirMax values, as in too much air coming in... I think.
      05-06-2018, 02:00 PM   #9
TLK
TLK's Avatar
112
You can pull the codes with any OBDII reader and see what it is. No need to be in the dark. Lots of chain auto parts stores will let you use one for a few minutes if you don’t have your own.
      05-06-2018, 08:40 PM   #10
Pikey Motorsports
Drives: M5
Code where volume airflow to low and bank 1 lean I've cleared the code done half a tank of fuel and it's stayed off so far after some hard driving
      05-07-2018, 01:20 AM   #11
YanoM5
Drives: 2018 Individual Nardo M5
I did charcoal delete and K&N drop in after a few months had the same code, Bank 1 lean. After research of this issue I did the recommended cleaning of the MAF with MAF cleaner. Reinstalled and no CEL since!
      05-07-2018, 09:04 AM   #12
steeve13m
Thankyou
Sounds like you just ran out of fuel....clear your codes and see if it comes back.....any sponge type filter does not filter well (from my research) and lets in lots of dirt into the engine...not good...
      05-10-2018, 06:40 AM   #13
Craze
Does the filter move around up and down?? (Not that its related to your problem)
      05-10-2018, 02:58 PM   #14
Pikey Motorsports
Drives: M5
I've done 300+ miles since resetting the code and all is well so far
      05-10-2018, 04:36 PM   #15
steeve13m
I recommend you switch to the BMS intake or K&N cone filters it has better filtering....you dont want small dirt particles entering your engine
