      04-24-2014, 09:12 AM   #1
is300wrx
Drives: 2014 M5
Valentine 1 Radar Hardwire-not off sunroof
I plan on hard wiring my Valentine 1 radar detector after work today. I need to stop by the auto part store to pick up a fuse tap kit. There is a nice write up in the DIY section on tapping it off the sun-roof; however, I want to see if there is a way to tap it off one of the fuses in the glove dept. I have done this successfully in the F01 750 and in the e92 m3.
Can you advise which fuse I can work off of? The car is fully loaded except for night vision and rear entertainment. Thanks guys
      04-24-2014, 10:41 AM   #2
avlnch
Drives: 2013 Individual M5
I do know it's possible to tap a fuse in the glove.
I would recommend using the sunroof though. Less wiring to route / seems like a cleaner install option?
      04-24-2014, 10:55 AM   #3
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
U should deff. Use the savvy connection its worth it.
      04-24-2014, 10:56 AM   #4
///SAL
///SAL's Avatar
When i tap into the fuse i usually use the Rearview camera fuse.
      04-24-2014, 01:10 PM   #5
is300wrx
Drives: 2014 M5
Im afraid of breaking any tabs when I remove the plastic housing off the sunroof.
      04-24-2014, 01:11 PM   #6
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
It's really easy to remove
      04-24-2014, 01:13 PM   #7
avlnch
As mentioned above, it's very easy to remove the light housing.
      04-24-2014, 01:35 PM   #8
is300wrx
Drives: 2014 M5
Do you recall what amp that fuse is? What about using the night vision since my vehicle isn't equipped with one?
      04-24-2014, 02:44 PM   #9
///SAL
///SAL's Avatar
Well thats even better use that but make sure u use that thing called tap a circuit
      04-24-2014, 03:34 PM   #10
savela
savela's Avatar
Drives: 2015 X5M
Running a power cable from the fuse box up to the V1 would be much more of a challenge as that A pillar has an airbag. Also would hate for you to ruin that alcantara!
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      04-24-2014, 04:40 PM   #11
GladiatorOwner
Drives: 22 M4C
54 or 48. 54 (bigger fuse) turns off in about 10 minutes, 48 (small size fuse) goes off immediately. Have 1 hooked up to my bel stir+ and the other to LI.
Just use 2 - 5 amp fuses, cause those taps are not suppose to go any higher. 54 is a 20, 48 is a 5
      04-24-2014, 05:59 PM   #12
v3n0m
Drives: 2013 MCB M5
I hooked up a dash cam and V1 to the rearview mirror. You don't have to pull any panels. Super easy:
http://www.bimmerfest.com/forums/sho...d.php?t=546557
Just the little connector behind the mirror.
      04-24-2014, 06:06 PM   #13
is300wrx
Drives: 2014 M5
Just finished the install. I ran the wire from the mirror to down the a pillar to the fuse box in the glove department. Wore nitrile gloves to protect alcantara from getting dirty/damaged. Tapped it off the lane departure fuse and used two 10 amp fuse. Tried with one 10amp on the fuse kit, but the lane departure would keep turn off so I added the second 10amp fuse to the fuse tap kit (has two slots). Seems to work perfectly without issues.
Now I need to swap out those front and rear reflectors with IND's painted ones...
      04-24-2014, 07:46 PM   #14
paulbrenneman
paulbrenneman's Avatar
Drives: Mineral Grey 335i M-Sport ZF
I second this. Just plug it in and hide the cables, totally reversible in like 5 minutes. Plus you don't get bombarded with alarms every time you drive into a supermarket parking lot.
      04-24-2014, 07:48 PM   #15
paulbrenneman
Those fuse tap kits have two fuses because one of for the original circuit and one is for the second circuit you are adding
      04-24-2014, 08:33 PM   #16
is300wrx
Drives: 2014 M5
...so I did good?
      04-24-2014, 08:34 PM   #17
paulbrenneman
...so I did good?
Yeah you did it right, you just need to have both fuse sockets filled because otherwise one of the two circuits won't work. If both sockets have fuses in them should work
      04-24-2014, 08:38 PM   #18
is300wrx
Drives: 2014 M5
Thanks
