      06-02-2022, 06:15 PM   #1
BlackBear
Drives: M6 Cab + M850 + McLaren 570Spi
Need an engine shop in Los Angeles for N63 S63 valve work
I think a valve might might not be working correctly.
ISTA is no help. I got misfire codes across bank 2, Cyl. 5 show very low compression. Car goes into limp mode. ISTA does a guided rough running test that starts with bank 1. That bank is OK. When the test goes to bank 2 ISTA stops the test because bank 2 runs too rough.
I have not done a leak down test yet. Waiting for the tester.
I need a shop that has ample experience doing valve seals, taking N/S63 valve cover gaskets off, etc.
Thank you.
      06-04-2022, 04:14 PM   #2
BlackBear
I did some more investigating yesterday.
It turns out Cyl. 5 has one intake valve that does not open at all. I put a camera in the cylinder and turned the crank.
I think the hydraulic valve lifter is faulty. If the spring was broken the valve would always be open.
Do you guys agree with my analysis?
I don't have the tools for this job, you need the AGA valve/timing tools to get the cam shaft out and remove the valve springs.
Who can do this work in Los Angeles?
      06-05-2022, 03:28 PM   #3
fstm5
fstm5's Avatar
146
Check out IKONIC auto
They've done most of my work if not all and do and outstanding job
Decent pricing as well
They're located in North Hollywood
