09-24-2016, 07:00 PM | #1 |
Rep 466
2007-2016 BMW DCT Clutch Relearn Procedure
Clutch install complete/ fluid filled to capacity 1) Transmission will need to be brought up to 80C temperature before any relearning can start. -Raise car on a hoist, and run thru each gear for at least 10 seconds (reverse also). This procedure will make sure that the work has been done correctly, while bleeding all the air from the valve body assembly. 2) Touch point learning procedure -E brake up (locked position) -Car in Neutral -Brake pedal needs to be held thru the entire procedure. -The RPM will “drop down” as the procedure progresses -After procedure is finished, make sure the car is in “Neutral” position, shut the ignition off. -“Procedure is successful” 3) Gear Learn Procedure -E brake up (locked position) -Car in Neutral -Brake pedal needs to be held thru the entire procedure. -3 different levels of shifting will occur with this procedure -After procedure is finished, make sure the car is in “Neutral” position, shut the ignition off. -“Procedure is successful” 4) Torque Curve Reset -E brake up (locked position) -Car in Neutral -Hold Brake Pedal Down -Ignition on, but engine off during this procedure -After procedure is finished, make sure the car is in “Neutral” position, shut the ignition off. -“Procedure is successful” 5) Valve body Relearn Procedure --E brake up (locked position) -Car in Neutral -Engine running HOLD ACCELERATOR AT 2000 RPM WHILE HOLDING THE BRAKE PEDAL -DO THIS PROCEDURE FOR 2 MINUTES -After procedure is finished, make sure the car is in “Neutral” position, shut the ignition off. -“Procedure is successful” PV1/PV2 RELEARN SUCCESSFUL The NEW clutch will need to properly be broken in for 500km of normal driving conditions. Absolutely DO NOT break the clutch in on a wheel dyno. Premature wear or clutch burning will occur. There is not warranty for this. Do not do any wide open throttle pulls. The clutch needs to be shifting frequently for proper break in of the clutch plates. After the 500km break in: For best clutch performance and longevity, do the following procedures: -On “M” Series cars make sure the clutch clamping force is turned all the way up, and traction control is OFF. This will allow you go gain 6 complete bars of pressure for proper clutch break in. On Non “M” Series cars make sure the car is in SPORT MODE for proper clutch break in. -Relearn the clutch touch points -Relearn the gear box at this time. |
apexlocator243.00 TheHouseWon644.00 Lerxst M4142.00 schnell1982345.00 M6Pilot31.50 q8kamikaze102.50 Bingly17.50 |
09-25-2016, 07:49 PM | #7 |
1087
Rep 1,968
09-25-2016, 08:05 PM | #8 |
Perennial PFC
336
Rep 1,275
That's interesting, a Chinese source. I guess that's common these days, but I was expecting Germany. Do you know if there is a European source for the same thing?
Just did a quick search, there's a Rheingold USA with no prices posted. The Chinese source is probably price friendly? If one doesn't have the BMW dealership do the install, and if the independent installer doesn't have the tool, this would pay for itself pretty quickly. Last edited by Used2be; 09-25-2016 at 08:21 PM.. |
09-25-2016, 08:22 PM | #9 |
1087
Rep 1,968
Sure - more expensive probably. The SW and license isn't included.
This can do everything the dealer can including the test plans - just that the dealer can get help from the factory on tougher problems. |
09-25-2016, 08:35 PM | #10 |
Perennial PFC
336
Rep 1,275
I did find the Rheingold USA store and the prices are the same, or close. But, they're out of stock at the moment. What is the "SW"(software?) Is the license required to actually do the adjustments?
09-26-2016, 06:44 PM | #11 |
Rep 806
Kris, is there any reason the dealer would have to reset or reflash the ECM or any modules during this procedure? When the dealership installed your kit they flashed over my tune and reset all my coding. Fucking pissed me off big time, gave me an excuse to try a different tune tho *silverlining*.
09-26-2016, 06:48 PM | #12 | |
Rep 466
This procedure has nothing to do with your tuning. They might have tried to do a reset if there were fault codes during the procedure. SSP Last edited by SSPKris; 09-29-2016 at 08:47 AM.. |
09-29-2016, 04:48 PM | #13 |
Rep 966
10-28-2019, 11:18 AM | #15 | |
Rep 147
Drives: E92 M3
Hi Kris , i did instal the clutch as your instructions (in order that I receive from you)
I have problems when learning procedure I did step 1. In the 2 step :Touching point learning procedure I try more than 4 times and it failed said “the value outside tolerance “ I haven’t try step 3,4,5 since step 2 ( touch point learning procedure) failed Should i do in order or if 1 step failed I proceed with other steps ? Quote:
10-28-2019, 08:56 PM | #16 |
Rep 466
I would check to make sure that the large snap rings for the clutch were installed in the correct places. Thick snap ring to hold the basket together. Thinner to hold the large clutch in place.
10-31-2019, 01:48 PM | #17 |
Rep 401
Hi kris, I’m about to tackle this clutch upgrade this winter in my garage and remember that you mentioned a pdf for the clutch install on this forum once or twice. Is there a way I can get that pdf emailed to me?
11-07-2019, 10:37 AM | #18 |
Rep 466
12-29-2019, 03:11 PM | #19 |
Rep 346
great info but does anyone have instructions on how to install new clutch pack?i just order ssp spec R and while i wait i have removed everything but the clutch pack itself. next step would be remove that and to take the basket apart to remove old and install new....not trying to mess anything up so if anyone thats done it has instructions please post here or send me a pm
12-30-2019, 08:46 AM | #20 | |
Rep 401
12-30-2019, 07:44 PM | #21 |
Rep 466
Yes, the clutch will come with complete instructions on installation and proper procedures on how to do the adaptations.
You are always welcome to email or call if you need further assistance. Kris |
01-07-2020, 02:36 PM | #22 | |
Rep 23
( i have changed the clutch on my E46 M3, and E60 m5 though)
