      06-02-2014, 05:14 PM   #1
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
For those who use M5 for Daily Driver
For those of you using your M5 as a daily and have to contend with winter weather conditions....
What tires are you using?
Anyone using the Continental DWS as a winter tire?
      06-02-2014, 05:30 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
those are not really winter tire, if you live in snow belt area. They may be alright for dusting of snow.
Michelin PA4. But they wear really fast. After 2 full winters of usage (with rotation), they are basically done as the car has too much torque applied to the tires. The PA4 has good traction to about 15cm of snow, anything more would be a bit of challenge.
      06-02-2014, 05:56 PM   #3
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
sottozero 240
worked well.
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      06-02-2014, 06:00 PM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Thanks guys.
Keep it coming....
      06-02-2014, 06:24 PM   #5
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Same here, with the Sottozero. I did the complete swap to the BMW Winter setup: http://www.shopbmwusa.com/PRODUCT/41...-TIRE-ASSEMBLY
I didn't traverse anything super nasty this past winter, but I felt fairly confident in the snowy conditions I was in.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      06-02-2014, 08:30 PM   #6
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Thanks eleven11.
      06-02-2014, 10:28 PM   #7
cassidysdad
feel bad for you
in los angeles never have to change tires
just worry about cooking the interior of my car
best wishes in the winter and drive safe
      06-02-2014, 10:49 PM   #8
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Originally Posted by cassidysdad View Post
feel bad for you
Thanks. If need be, I'll purchase another vehicle and/or use my wife's X5. I work from my home office, so I don't HAVE to drive in inclement weather. So I just want some tires that can get me through wintry weather, not storms/blizzards.
On the plus side... It gives me the chance to change the look of my ride twice a year.
      06-03-2014, 07:09 AM   #9
DrewM5
Drives: SG E60 M5
I have the Sottozeros which are a great high performance winter tire, but they are on the performance end of the spectrum. They are a winter tire NOT a snow tire. There is a big difference. The PSS are terrible in the snow, but they are also pretty bad in the cold temps even when the roads are dry. It is not what their compound is designed for. They will also wear much more quickly when used in the cold temps. So you are actually being fiscally responsible by buying a winter setup.
You defnintely need winter tires in the Northeast. But if you are looking to be able to use the M5 in anything but a dusting to an ich or so, you might be happier with the Blizzaks. If you want to be able to be out there in a few inches of snow or more, I have no suggestions.
      06-03-2014, 07:17 AM   #10
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
Bridgestone Blizzacks, they've been great. Good cold weather performance and reasonable traction in snow. Also, the wear has been phenominal - I may have to replace them due to age before I run out of tread!
      06-03-2014, 09:17 AM   #11
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
thanks!
      07-09-2014, 07:44 PM   #12
Stuartlogan77
Drives: 2013 BMW M5
I have blizzaks no good for cold temps vs Pirelli you loose all the great M feeling actually quite depressing. If your driving on snow there great if your in NJ 99% on treated Tarmac pirellis the way to go.
      07-16-2014, 09:37 PM   #13
MBrown1003
Eight Bimmers and counting
Drives: 2014 F10 M5
I am in Massachusetts, and I have a 550i as a daily driver. After three winters, I'm on my second set of Dunlop SP Winter Sport 3D tires. First set was shot after 13,550 miles.
The car did extremely well on the tires, driving in all kinds of winter conditions, including heavy snow.
I agree with previous comments about considering low temperatures, even without snow. The car can be quite a handful on summer tires when the temperatures are down in the low 40s (F) or below.
2014 F10 M5
Previously...
Threes: '08 E90 M3, '07 E92 335i,
Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i
Others: VW, MBz, Peugeot, Toyota, Olds
      07-16-2014, 11:03 PM   #14
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
I purchased the BMW winter wheel and tire package with the Pirelli Sotozero's and style 409 wheels. Squared config with 255's on 19"s at all four corners.
I am home office based, so I am able to stay in when needed. And if I must go out, my wife has an X5 with Conti DWS tires. It did great this past winter here in Philly.
      07-21-2014, 10:10 PM   #15
M5stallion
Italy
Drives: Bmw M5
I use nokian winter tires, they were better than the common Pirelli and Michelin performance snow tires and handled better in the dry as well. The tail happy m5 was tamed for winters if that is possible
