      01-16-2014, 03:21 PM   #1
Tylerstar
Tylerstar's Avatar
69
Loss of power
I was doing about 140, when the light came on that I lossed power. Any idea why this happened. Or is this just a glitch with the cel, I'm running catless dp. A simple restart fixed the problem.
      01-16-2014, 03:26 PM   #2
Neil McRae
BMW Motorsport
Neil McRae's Avatar
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
what year?
there was a software bug that would cause a drivetrain problem.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      01-16-2014, 03:29 PM   #3
Tylerstar
Tylerstar's Avatar
69
      01-16-2014, 04:51 PM   #4
mstmng
Drives: M5 F10
how many miles u hv done on catless dp's?
      01-16-2014, 05:59 PM   #5
Tylerstar
Tylerstar's Avatar
69
About 1000, I think its definitely software related.
      01-16-2014, 09:08 PM   #6
avlnch
Drives: 2013 Individual M5
Just to verify, when you say a light appeared you mean the CEL (check engine light)?
Could be a few things.. it could be your catless dp's or a faulty O2.
Were you WOT when the CEL appeared?
      01-16-2014, 09:34 PM   #7
Tylerstar
Tylerstar's Avatar
69
Not the check engine light, thats already on LOL. A different code saying maximum power output not available. After it came on I slowed down because it wouldn't rev over 4000RPM's. Hopefully nothing to be considered about, but definitely odd.
      01-16-2014, 10:01 PM   #8
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
That is the speed when Drivetrain malfunction error comes on when you have catless downpipes.
I am currently testing something to avoid that problem. Check my thread. I will confirm by this weekend whether it has full functionality.
http://f10.m5post.com/forums/showthread.php?t=934437
      01-16-2014, 11:40 PM   #9
avlnch
Limp mode. Were you WOT?
      01-17-2014, 03:23 AM   #10
shahano
RPi Downpipes will cause the engine light to come on?
      01-17-2014, 04:00 AM   #11
mstmng
Drives: M5 F10
Any catless dp's will cause CEL, but there is already plug-in cable which clears it! Greenturbo is testing it atm'
      01-18-2014, 06:27 AM   #12
boots
Curve Thrasher
boots's Avatar
623
You can continue to drive your car with the mal light on. It will reset in about 140 miles even if you shut it off and the light is still there.
Country run
      01-18-2014, 01:21 PM   #13
avlnch
They sell OBDII bluetooth dongles paired with an iOS app. Allows you to read out values, error codes, and clear codes.
I understand your malfunction error is not the CEL. Might be worth a try to see if that app and cable will clear your malfunction though.
      01-18-2014, 02:30 PM   #14
mstmng
Drives: M5 F10
In his case malfunction error is connected to cel, as you get a lot more air flow, which is not set up to be normal for ecu, so ecu tries to protect your engine by limiting the power! Once you drive normally, ecu thinks everything is alright and u get power back
If u get thatd OBDII cable, as greenturbo mentioned above, you should be fine, as you have no cel, so the malfunction error never comes back
Thats how i c it
Might be wrong, but makes sense
      01-18-2014, 03:38 PM   #15
Neil McRae
BMW Motorsport
Neil McRae's Avatar
2015 BMW M4  [10.00]
sounds slightly suspect!
      01-18-2014, 04:43 PM   #16
Tylerstar
Tylerstar's Avatar
69
Exactly what Mstmng said. So I guess this is just another code that can pop up from the downpipes. Probably from me driving it hard, paired with the colder weather/increased air flow.
      01-18-2014, 05:53 PM   #17
boots
Curve Thrasher
boots's Avatar
623
If you bang the low gears pretty hard 3-4 you will get one
Country run
      01-18-2014, 06:38 PM   #18
mstmng
Drives: M5 F10
just came back home from a glory ride
      01-19-2014, 11:55 AM   #19
boots
Curve Thrasher
boots's Avatar
623
Rub it in bro!
      01-28-2014, 01:31 PM   #20
Tylerstar
Tylerstar's Avatar
69
Happened again the other night around the same speed. Its almost like after a couple of hard pulls the ecu starts to die down. Restart and I get my boost back. I hope my car isn't limited to 140MPH?? MEHHHHHH
      01-28-2014, 02:57 PM   #21
boots
Curve Thrasher
boots's Avatar
623
When you got your light, did you pull right over and do a restart or continue to drive and later restart.
Country run
      01-28-2014, 03:02 PM   #22
Tylerstar
Tylerstar's Avatar
69
I stopped a little after at a gas station to reset. It will still drive but it won't rev over 4k RPMS. And the exhaust is actually louder between those RPMS. Kind of weird.
