      04-11-2024, 04:13 PM   #1
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Just posting this here because I was actually surprised at the outcome of my first ever attempted bumper repair. I did this for my uncle ‘s car using a hot air gun at high-speed.
It certainly worth a try if you ever have something like this happen to you and want to leave out insurance.
I had to replace the tail light, got that on eBay for $75.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
Llarry16753.50
      04-11-2024, 04:56 PM   #2
BMWCCA1
BMW Owner Since 1971
2276
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
I did the same on my wife's E90, but I had to take the bumper off and push from the inside. Did you do that in-place?
fe7565556.50
      04-11-2024, 05:20 PM   #3
fe7565
fe7565's Avatar
Yes, I was able to do it in place by first pushing it out first with the curved handle of a plier, And then get the remaining shallow dent out with my hand. Got lucky in that aspect that didn’t have to take the whole bumper off, but I would definitely take it off if can’t get to it properly.
      04-12-2024, 04:04 AM   #4
DmaxBMW
DmaxBMW's Avatar
42
Drives: BMW X3 M40d
Looks like a great job, well done.
As someone who has worked as a professional dent repairer in the past (on metal panels) I was occasionally asked to improve dents in plastic bumpers, as an alternative to putting them through the bodyshop. I used exactly the same method with a heat gun and pressure from behind.
You did exactly the right thing by moving the heat gun really fast, as a word of caution to anyone else trying this make sure not to get the plastic too hot as the paint will crack and bubble pretty easily, as I've found to my cost on more than one occasion!
fe7565556.50
      04-12-2024, 04:10 AM   #5
fe7565
fe7565's Avatar
You are very correct. I should’ve mentioned that you have to move the heat gun quite fast and not only over the dent but a bit outside its perimeter as well.
      04-14-2024, 10:33 AM   #6
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
Nice Job!!!
Looks Great!!!
fe7565556.50
      04-14-2024, 12:02 PM   #7
M3SQRD
M3SQRD's Avatar
2450
Drives: E92 M3,G20 330ix,F22 240iX,F82
Excellent work! You can barely tell that this corner of the car had a decided dent and cracked paint. Looks great.
fe7565556.50
      04-14-2024, 02:28 PM   #8
fe7565
fe7565's Avatar
Thank you. I ordered on EBay a paint match kit with clear coat and will try to fix where the paint cracked. I think this part will be more difficult not messing up. But it does not have to look OEM, just should pass the 2-3 feet test.
      04-15-2024, 09:12 AM   #9
MADBMWX5MC
MADBMWX5MC's Avatar
1021
Drives: 2023 BMW X5MC
OP, that's some great work there.
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
fe7565556.50
