      05-19-2018, 01:56 AM   #1
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
My car broke.
I just purchased the car 700 miles ago and ~20 days. Fortunately I purchased a warranty that has immediate coverage and it will be towed to service on Monday.
I have driven the car a little rough but nothing major. I pulled up to a stop sign and my car just shut off. Prior to this it was running completely fine and I had driven all day. The car would start for 10 seconds and then die and the whole time it had a super rough idle. I was able to get it started long enough to get it to my house 1/10 mile away. I started it this morning and just straight gasoline smell with white smoke billowing out of the exhaust big time. After I turned the car off the white smoke was still coming out of the exhaust for a while. It is also showing drivetrain malfunction constantly and running like garbage.
I know my car is getting looked at Monday but I'm just curious as to what this could be?
It's a 2013 DCT with 41k miles.
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
      05-19-2018, 10:08 AM   #2
apexlocator
Drives: 2014 M5
I had a lot of white smoke from my exhaust, drive train malfunctions, misfires on either side banks....and car suddenly died while driving slowly through my neighborhood; luckily couple blocks from my house.
Turned out it was my in-tank low pressure fuel pump failing. Had it replaced along with EKPS unit and everything is right again.
      05-19-2018, 12:36 PM   #3
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
Thank you for the reply. Luckily my warranty company is able to get a flat bed out today. I will update this thread as I hear more if anyone else has a similar problem. I died only a couple blocks from my house too. Thank goodness. I was able to start her up and limp it home instead of pushing.
      05-19-2018, 10:44 PM   #4
AWF10M5
Drives: f10 m5
Sounds like a injector
You from Texas? Did u buy this car from Houston direct auto by any chance ? Black ?
      05-20-2018, 07:19 AM   #5
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
No, I had it shipped in from Little Rock, AR.
      05-20-2018, 06:00 PM   #6
1MEANM6
1MEANM6's Avatar
Drives: M6 GranCoupe
Same thing happened to me 2 years ago right after pulling out of the dealership,turns out to be high pressure fuel pump failing.BMW replaced all injectors on bank 2 and high pressure fuel pump.
      05-21-2018, 12:26 AM   #7
AWF10M5
Drives: f10 m5
Little rock? Car had dinan wheels, and dinan tune right?
      05-21-2018, 11:03 PM   #8
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
My SA said it definitely sounds like a fuel problem and is probably an injector or the fuel pump. I will hear more tomorrow morning.
      05-21-2018, 11:04 PM   #9
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
It has 343M wheels and is not tuned to my knowledge.
      05-22-2018, 02:07 PM   #10
nismonian
Had the same exact thing happen to me during a run at an 1/2 mile event. turned out it was an injector and got the whole bank replaced along with the cat on that side from being drenched in fuel.
      05-23-2018, 08:31 AM   #11
Herofmine
Herofmine's Avatar
Drives: E92M3, F10535i, 15 M5,340i,X5M
2015 X5M  [10.00]
Low/high fuel pressure pumps are weak on any bmw. I may change mine before it dies on me.
      05-23-2018, 08:37 AM   #12
boots
Curve Thrasher
boots's Avatar
623
Would this be a beware of buying this car you are talking about so I can warn my buds who might want to get a car from them
Country run
      05-23-2018, 10:21 AM   #13
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
BMW stating that all injectors and spark plugs need to be replaced. The injectors failed on cylinders 4,5,6 I think.
      05-23-2018, 01:11 PM   #14
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
Another update. Total of 4 failed injectors. All 8 injectors being replaced under limited warranty factory BMW warranty Injectors to 100k/mi 10yr.
      05-23-2018, 01:46 PM   #15
AWF10M5
Drives: f10 m5
Houston direct had a 13 for sale with 41k miles for like 38k almost had every package but had a accident. Still the price was good but when I did some research I realized the car was for sale for over 2.5 years. Not sure why it didn't sell for
So long but someone bought it recently thought that might be OP.
      05-23-2018, 01:47 PM   #16
AWF10M5
Drives: f10 m5
I knew it would be injectors. Maybe your car was sitting for a while as well ?
In any case glad you got it taken care of under bmw warranty. Do u have a aftermarket one too?
      05-24-2018, 07:58 AM   #17
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
Yes, I have an aftermarket warranty as well. They would've covered the repair had I not called BMW USA to ask about the injectors and see if my vin was apart of the extended injector warranty. My SA had no idea.
