12-03-2013, 10:43 AM | #1 |
Rep 149
Broke my rear axle!!!
On thanksgiving day I broke my rear axle, I had the car towed to Union Park BMW in Delaware. They took a look at it and confirmed the axle was broken, but they will not cover it because the suspension has been modified. I have H&R springs on the car. My service rep said the modification does not void the warranty, but if something happens it is taken into consideration. I had the car towed to my local mechanic where I will have the repair done. Can the dealership just not cover it over H&R springs?? Did the springs really make it easier for my axle to break?
12-03-2013, 10:46 AM | #2 |
Rep 617
Try taking it to another dealer. It is the shop foreman's call if it is going to be covered or not. IMO it is worth the hassle of towing to another dealer if you can get it covered under warranty.
12-03-2013, 10:54 AM | #3 |
Rep 149
I talked to another dealership, which is the closest one at 30 miles from me. They also said because the modification they will not cover it. It looks like I'm stuck with the bill.
12-03-2013, 11:44 AM | #6 | |
Rep 784
12-03-2013, 02:32 PM | #8 |
Rep 149
The axle broke when i was doing something I've done for years. I was making a U-turn and I let the back out to get the car sideways, when I was getting it back on track I threw it in second and BOOM! I've been doing this for years in numerous cars and never got this result. Could my tune have played a factor? Too much power? (Is there really a such thing) I've asked my mechanic what the part is I'll let you know when he gets back to me. BMW quoted me north of 2k, my mechanic is doing it for $1500. He's a good friend of mine who also own a M5. The part is coming from Germany and will take 14 days to get here.
12-03-2013, 02:47 PM | #9 | |
Rep 1,155
http://www.consumer.ftc.gov/articles...ne-maintenance Your mechanic should be able to tell you whether the H&R springs reasonably played a role in the broken component or not. If not, I'd pursue this with BMW/NA.
2009 Aston Martin DBS - Casino Royale Gray on Black (sold) 2014 M5 ZCP - Azurite Black over SSII Full (gone) 2009 M5 - Carbon Black over Sepang Full (gone - not forgotten) 2001 740i M-Sport - Carbon Black over Black (gone - not forgotten) |
12-03-2013, 02:47 PM | #10 |
Rep 646
Did you feel any axle tramp (bouncing) before the "BOOM"? Was the road surface smooth or bumpy? What type of tune are you running?
I would theorize that maybe going sideways was puttting a lot of lateral force on the axle...combined with maybe an uneven road surface and more torque from the tune... it may have been a perfect storm of bad facts to cause the axle failure. Good luck with the repair and thanks for posting and giving us a heads up! |
hunternight544.00 |
12-03-2013, 02:55 PM | #11 | |
Rep 784
12-03-2013, 02:56 PM | #12 |
Rep 1,583
Agreed, to not repair the car because of springs is ridiculous.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
12-03-2013, 03:27 PM | #13 |
BMW Motorsport
235
Rep 2,225
Drives: BMW ///M4 F82 / BMW ///M5 F10
take it up with bmw usa
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White |
12-03-2013, 03:41 PM | #14 |
Rep 806
Bad luck man. I probably have 20+ passes at the track on drag radials and before that insane wheel hop on stock tires so bad I am surprise that I have not broke an axle. *touches wood*
I highly doubt the couple degress the springs changed the half shaft angle would put that much extra load on them. How much is your drop? Did BMW beef up the shafts with the drop on the CP package? No.
12-03-2013, 04:15 PM | #15 |
Rep 149
BMW NA contacted the dealership and this is what I got. The dealership can not prove to bmw warranty that the part was defective. They can not prove the springs played a role but because the suspension is altered the dealership can not be certain the broken part was defective. BMW NA took side with the dealership.
12-03-2013, 04:25 PM | #16 | |
Rep 784
12-03-2013, 04:53 PM | #17 | |
Rep 200
12-03-2013, 05:38 PM | #19 |
Knight Commander
559
Rep 5,948
Well there you have it. I won't be using aftermarket springs ever on a BMW.
2022 Mercedes-Benz EQS 580
12-03-2013, 05:41 PM | #20 |
BMW obsessed
9578
Rep 10,873
Did your mechanic identify which component of the axle was broken? Was it the shaft of the axle, or the CV joint?
Lowering springs or any normal amount of lowering, even with a threaded body damper solution like something from KW would not cause premature wear that would reveal itself on such a short time frame. On a long enough time frame, extreme lowering can wear a CV joint slightly faster than normal due to an odd angle at the joint, but given how new the F10 M5 is I don't believe this can be a factor. If the shaft itself snapped in half this is outright in no way related to lowering. If it's a bad CV joint you will have a more difficult time making a case, although I do not believe at all that this is related to lowering either, just that BMW is more likely to have a successful case and deny your warranty claim.
12-03-2013, 05:41 PM | #21 |
Knight Commander
559
Rep 5,948
FYI here's another case of broken axle. Doubt this car was lowered.
http://f10.m5post.com/forums/showthr...ht=Broken+axle
