03-13-2015, 10:11 PM | #1 |
Rep 526
Double-lock feature
Hello,
Sorry if it was discussed before. I was wondering how does the remote keyless entry double-lock feature work? It is stated that it is coded by the dealer. Thanks in advance for your input. |
03-14-2015, 08:48 AM | #2 |
Rep 10,185
The "double-lock" feature is that when you lock the door the lock moves in a "double locking" fashion that makes it impossible to open the door from the outside or from the inside of the car.
This prevents someone smashing a window and opening the car door or putting a wire through a small gap or the sunroof and opening the door by pulling the interior door handle. This has been standard on BMWs for a long time. No coding needed. Its activated when locking via the key remote or via the normal comfort access (keyless) locking method. Remember about this feature when you leave the car with someone inside. If you lock the car with the remote or via the keyless touch, they will NOT be able to get out the car. Rather have them lock the car from the inside via the lock button on the dash. Then they can open it again themselves if they need to get out.
03-14-2015, 08:55 AM | #3 | |
Rep 526
03-14-2015, 12:24 PM | #4 |
Rep 10,185
Could you give me a link so I can read what they say ?
03-14-2015, 12:40 PM | #5 | |
Rep 10,185
Never mind, found it
Dont think the "programmed" bit refers to the double lock, but rather the whole alarm system. And that should also fit more with cars that dont come standard with alarms, but can have them fitted at the dealer (like some USA 3 Series ect) Think it was cut and paste from somewhere.
03-14-2015, 12:47 PM | #6 |
Rep 526
Sure, from the left side options under Learn pick "features & specs" then at the top pick "standard features" then scroll down to safety and security...
http://www.bmwusa.com/standard/conte...n/default.aspx |
03-14-2015, 12:50 PM | #7 | |
Rep 526
