08-19-2017, 12:40 AM | #1 |
Rep 167
Gintani Tune Review (724rwhp on 110)
I just got my car back from Gintani and I am at a loss of words! Alex (owner/tuner) knows a lot about our cars and it's evident the moment you start chatting with him. I was originally just going to have my downpipes ceramic coated and installed there but after lengthy conversations I decided to have him tune my car as well. So they ceramic coated and installed my Evolve catless downpipes, installed my MSR intake and changed out my spark plugs for NGK ones. With the mods installed, it was time to start tuning.
My baseline dyno (dynojet) showed 525 rwhp and 531 rwtq. I then had a conservative 91 tune done (thank you shitty CA gas), resulting in 607 rwhp and 597 rwtq at 20psi. And for the grand finale, we did a VP 110 race fuel tune that led to an astounding 724 rwhp and 693 rwtq at 23psi! I picked up my car with race gas in it and I can't stop smiling. The power is insane, drivability awesome, and between the MSR intakes, catless downpipes, and exhaust noises Gintani is known for, the sounds my car makes are out of this world. Every one of my "car friends" that have ridden in it so far can't believe this is a BMW. The only weak point on my car right now are the tires...These Michelin Pilot Super Sports might as well be OE on a Prius so R888Rs are on the horizon. I should have them on in September, giving me plenty of time to prepare for Shift S3ctor in October. And switching between fuels is easy with the tablet you can opt for. They loaded both of my tunes onto this little windows tablet that I can keep in my car and use to flash either my 91 or 110 tune. So I never have to worry about running out of race gas and getting stranded somewhere which is a huge relief. While I could keep going and going, I can't stand being away from my car for this long. I have some long drives ahead of me this weekend so expect more info later. Until then... enjoy this dyno graph and vid Last edited by DHUBM5; 08-31-2017 at 01:25 PM.. |
08-19-2017, 06:29 AM | #3 |
Rep 8,083
this is a flash tune?
i'd be wary of running racegas, that's a whole lot of power, that your car is not equipped for. have them do another tune for 91, they should be able to get into the 620-640 range. 720 wheel is asking for trouble. |
08-19-2017, 09:33 AM | #4 |
Rep 167
Yes, it's a flash tune.
Why do you say it's asking for trouble? I've seen a handful of people on the forum running higher power levels with a stock bottom end. Unless you are referring to mods such as clutches and meth?
2014 BMW M5 Comp Singapore Grey Metallic
Modifications: Gintani tune (91 and VP110 (724 rwhp)), MSR intakes, Akrapovic EVO exhaust, HRE S101, Evolve Catless Downpipes, Michelin PS4S, Vorsteiner Rear Diffuser, RW Carbon front lip and rear spoiler, M Perf Alcantara Steering Wheel, IND paint matched front and rear reflectors, Rayno nano carbon ceramic tint (40%), Hardwired Escort 9500ix |
08-19-2017, 11:44 AM | #5 |
Rep 881
Those are nice numbers and a neat feature to switch between tunes
Look out for clutch slippage at those VP110 wtq levels, and if you switch to R888Rs...maybe rear axles.
2014 "AW/SO"me M5
08-19-2017, 12:11 PM | #7 | |
Rep 8,083
you dont even have turbos. You are asking too much of that car to be pushing 720wheel. and besides, you wont be putting 720 down on the road w/o clutches. So essentially that number is nil. Dont take what i'm saying the wrong way. But what i said is worth noting. |
FSociety3812.50 |
08-19-2017, 12:27 PM | #8 |
Rep 5,233
720 WHP will be hard on the clutches as well as the axles especially on the R888's.
I assume you're aware of the risks and issues that can present themselves at these power levels, if not all you need to do is read through these forums to get a better idea. I was on the fence about tuning until I saw several first hand examples of blown engines where the owner has had to foot the bill for a new / rebuilt engine. Very difficult, if not impossible these days to get this covered under warranty by BMW as they can easily detect a tune / drilled DME's. Some may argue we're still in the good old days when SA's looked the other way but I will disagree as BMW NA will not. I'm not trying to dissuade you from staying at these power levels just saying to be careful ... seen damage at much lower power levels.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 Last edited by josec70; 08-19-2017 at 12:38 PM.. |
08-19-2017, 05:26 PM | #9 |
Rep 167
Thanks! Yeah, I know at some point I'll have to do the clutches.
08-19-2017, 05:31 PM | #10 |
Rep 167
Haha! The tune does have a burble feature... makes deceleration quite interesting.
08-19-2017, 09:54 PM | #11 | |
Rep 167
08-20-2017, 06:59 AM | #12 | |
Rep 5,233
DHUBM529.50 |
08-20-2017, 01:24 PM | #14 |
Rep 167
22,000 miles. So far the clutches aren't slipping This thing is a complete beast. Went to dinner with my fiancé last night and trying to drive it slowly is quite a feat now..haha.
08-20-2017, 03:11 PM | #17 |
Rep 167
I'm still running race gas (almost out though) so I'll let you know once I switch to 91.
08-20-2017, 03:13 PM | #18 |
Rep 167
Thanks man! I need to charge my GoPro so I can show you guys what it looks/sounds like when I'm driving around. I've never heard anything like it.
08-22-2017, 03:49 PM | #20 |
Rep 167
I will try to get my GoPro out this weekend but it might have to wait until next weekend
08-23-2017, 02:47 PM | #22 |
Rep 167
Edward376.50 |
