      09-03-2017, 09:54 PM   #1
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Drives: BMW F13 M6 CP GT3
Anybody try ECS Tuning 90c Thermostat?
Hi guys,
Anybody try the ECS tuning 90c Thermostat??
https://www.ecstuning.com/BMW-F10-M5...ng/Thermostat/
And do you think it will fit an F13 M6, it's not listed as compatible on that car.
[IMG]https://c1552172.ssl.cf0.rackcdn.com/625497_x800.jpg[/IMG]
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
      09-05-2017, 10:21 PM   #2
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Wouldn't that cause a rich mixture?
      09-06-2017, 10:37 AM   #3
apexlocator
Drives: 2014 M5
All it should do is let the engine start to cool itself earlier.
      09-06-2017, 01:30 PM   #4
financenick
Drives: BMW M5 F10 - 2016
I like the look of this, love keeping things cooler, does anyone know where the Thermostat is located on M5 F10 ????
      09-06-2017, 02:31 PM   #5
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Exactly right. For those who think the engine will run cooler with this thermostat, think about it a little more..... Now take the thermostat out completely. Will the engine run really, really cool now? The thermostat doesn't cool the engine, the coolant and the radiators cool the engine.
You want the engine to come up to operating temperature more quickly, hence the thermostat. The capacity and efficiency of the radiators will determine the temperature of the coolant after the proper running temperature is reached. If you've built a high HP motor, you'll need more radiator capacity, not a thermostat that opens earlier.
      09-06-2017, 04:10 PM   #6
DHUBM5
Drives: 2014 BMW M5
The colder thermostat could also lead to more consistent power. If the engine gets too hot, the computer will start to pull timing which can be an issue when racing. By allowing the engine to get "cooler" earlier, this could prevent the timing from being pulled and allow for more consistent back to back runs.
This is the first mod my Z06 friends do and since our computers pull timing too, I would assume this could benefit us as well.
2014 BMW M5 Comp Singapore Grey Metallic
Modifications: Gintani tune (91 and VP110 (724 rwhp)), MSR intakes, Akrapovic EVO exhaust, HRE S101, Evolve Catless Downpipes, Michelin PS4S, Vorsteiner Rear Diffuser, RW Carbon front lip and rear spoiler, M Perf Alcantara Steering Wheel, IND paint matched front and rear reflectors, Rayno nano carbon ceramic tint (40%), Hardwired Escort 9500ix
      09-06-2017, 07:11 PM   #7
TheHouseWon
644
Drives: 2013 M5
OP, the ECS link shows F13 m6 as an application for the thermostat. I see that FCP Euro has the best price, but I havent checked ebay or aliexpress RM European has good pricing on stuff, too.
As far as location download the engine manual from here http://f10.m5post.com/forums/showthread.php?t=803494
      09-07-2017, 03:48 AM   #8
financenick
If your sitting stationary, your absolutely correct, there is no difference.. BUT if your driving around allowing the air to cool the rads etc, it will run cooler with the 90c thermostat..
It just wont make it run cooler ALL the time
STILL CANT SEE WHERE THE THERMOSTAT GOES EVEN WITH THE MANUAL
      09-07-2017, 08:52 AM   #9
TheHouseWon
644
Drives: 2013 M5
Go to page 47 of the engine manual, the attachment with a size of 2.82 mb. The section under Cooling Systems shows it as a Map Thermostat.
      09-07-2017, 08:57 AM   #10
financenick
AHHH thank you, got it.. Just got to figure out if it needs any special bleed techniques after and im good to go
      09-09-2017, 01:03 PM   #11
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
Why you want new termostat. put your car sport+ and termostat and cooling lines are 100% open.
efficiency mode water temperature 98-104 celsius
sport mode same
sport+ drops about 20 celsius. mine goes around 78-86 celsius
      09-09-2017, 01:11 PM   #12
TheHouseWon
644
Drives: 2013 M5
^saved us $80
      09-09-2017, 04:52 PM   #13
financenick
sport mode same
Had no idea the car was that advanced? so press one button and cools more ??
      09-09-2017, 07:00 PM   #14
Used2be
Perennial PFC
Used2be's Avatar
I don't know if you're being sarcastic or not, but you are aware that the M5 uses a map-controlled thermostat? If you don't know of the map-thermostat please read the pdf from Mahle. It will come up if you Google 'map thermostat'. I think it makes spending $100 on the Hamburg Tech thermostat from ECS a waste of money.
      09-30-2017, 04:03 PM   #15
BMWAUDIO
Drives: F90 M5 Frozen Gray , 997 C4S
This is what you need if you want to lower your temps , Lucky for you I have the system available for sale now .
This is the system that was on Allmotor_2000 car .
This is a one-off kit that is fully custom and probably the only setup that actually works. People have tried all sorts of gimmicks but they don't work. It took months to figure it out.
Has a 55gph Meziere pump (these run $550 just for the pump). Custom Ice-Tank with aluminum hard-lines including a 'burpee' to remove air-pockets. The hard-lines run until the DCT and then it is hoses to the IC's.
Without ice I can keep the IAT's < 90 through a 1/2 mile pass. With ice a frigid 55-75 in a 1/4-mile. Just having the extra 4-5 gallons of water makes a HUGE difference. Keep in mind a stock M5 will hit 115-125 degrees easy.
People buy intakes for $2K... this is something that actually helps. It doesn't make power (obviously) but ensures you keep everything you got! If you make 700whp on the dyno with your hood open, you are actually making 650whp on the street. This makes sure you have all 700whp on tap. If you put ice, you gain much more. I can run more timing which is safer for the motor with lower IAT's.
Here is the original thread from the build:
http://f10.m5post.com/forums/showthread.php?t=1201845
The picture is how it looks today. Originally had a Rule bilge-pump setup (which sucked) and had to figure things out. The hard-lines etc. are the same.
      09-30-2017, 08:36 PM   #16
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
^^ looks familiar!!
      09-30-2017, 09:57 PM   #17
TheHouseWon
644
Drives: 2013 M5
Did RK ever complete the intercoolers?
      10-01-2017, 03:44 AM   #18
financenick
Thats a good point, was going to fit the RK charge coolers and carbon driveshft next - but RK taking their time !!
