      11-16-2017, 01:33 AM   #1
Pho3niX90
Drives: 2013 F10 M5 BSM
2013 M5 vibration on hard acceleration
Hi Guys,
So since I bought my M5 I have noticed a vibration on hard acceleration around 150kmh, I have tried balancing the mags as well as replacing all tyres. I recently dynoed the car and the vibration was worsened 20x, so much so that the dyno technician decided not to take it past 5000rpms.
In any other conditions the car is perfect with no vibrations whatsoever, I am completely lost at what the issue can be, I have visually inspected the guibo and all seems fine.
Any suggestions?
      12-30-2017, 04:14 AM   #2
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
In a safe location try accelerating hard with the trans in MDM mode, or DSC off (if you're brave) to see if it vibrates. If it doesn't, then your DSC is kicking in when your in normal driving mode
      03-20-2018, 04:18 PM   #3
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Or check the engine mounts.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      03-21-2018, 10:52 AM   #4
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Check if the transmission mounts are broken (happen) and/or the driveshaft bolts are loose!
