      04-29-2017, 11:16 AM   #1
2016-M5
Drives: M5-2016 Grey
Finally got meth working, but now gearbox feels odd ?
Hi,
Finally got round to turning meth on today, it took quite a number of blasts before it started to adapt (at least 1 hour) first few runs felt almost normal, but then slowly the power really increased - so very pleased to now have the cooler temps and a bit more power.
HOWEVER on the odd occasion taking the revs up to say 6000 rpm in 3rd or 4th then letting off the throttle leaving it to just decelerate on its own, after a couple of seconds i felt a lunging feeling like ive been hit from behind, feels very much like gearbox just engaged a lower gear for a split second causing the car to drag but then corrects itself very quickly, just wondered if anyone else ever had this?
My clutches are stock (for now) so maybe their the culprit?
      04-30-2017, 06:33 PM   #2
wheelpro
wheelpro's Avatar
Egypt
175
Drives: M5,F10,JB4,DP,CP,METH,SSP
whats your math scaling , additive ,start flow in meth setting ???
      05-01-2017, 11:27 AM   #3
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
What are you using to control your meth?
      05-01-2017, 12:13 PM   #4
2016-M5
AEM METH KIT, but tbh ive felt it before but much less noticable, turn meth on and can really notice it?
      05-01-2017, 12:15 PM   #5
MissionPerformance
Are you using a flash tune or piggyback?
      05-01-2017, 03:54 PM   #6
2016-M5
im using a 21 psi flash tune
      05-01-2017, 04:38 PM   #7
MissionPerformance
Did it start happening after tune? If so, contact your tuner since the symptoms you are explaining seem to point to turbo still trying to pump air into the motor even though you are requesting nothing.
      05-02-2017, 08:10 AM   #8
2016-M5
Makes sense, thanks for your time to answer my concern
      05-02-2017, 09:20 AM   #9
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Try re-adapting the DCT
2016-M535.00
      05-02-2017, 10:45 AM   #10
2016-M5
Yes, was thinking same, new clutches being fitted soon so guess that will happen during the relearning process
m5 f10 gearbox, m5 f10 meth
