      11-20-2013, 02:52 PM   #45
bobblehead
bobblehead's Avatar
Drives: warp speed
for aftermarket pads, hella/Pagid is coming out with theirs soon (front). They have rears available already.
      11-25-2013, 02:35 PM   #46
FLOMACKS
FLOMACKS's Avatar
Drives: 2024 X7 M60
Same problem. Took it in today and they gave me the "working as designed" story. Sucks, mine squeal LOUD.
2007 550i
2012 BMW - M5 European Delivery
2014 911 C2S- Agate, MT, PDCC, SC, SE
2015 S63AMG Sedan
      12-02-2013, 07:50 PM   #47
tven99
GOVNER
Drives: 13' M5, 05 P71, 15 SP CHLGR
same problem, usually happens when I'm doing city or heavy traffic driving. at low speeds
I'm past the 10,000miles now
      12-04-2013, 05:31 PM   #48
Lual
Drives: M5 2014 CP / X5 G05 ‘21
Same noise here.
Just after the break in service at 2200km
This should not happen in a + 100.000 car
      12-05-2013, 05:13 PM   #49
Willie_Beamen69
Drives: BMW M5 F90
I've had the same problem too in at about 6000 miles but when i changed into my winter wheels it stopped completely.
      12-05-2013, 07:36 PM   #50
Un Gato Malodoro
Un Gato Malodoro's Avatar
Drives: 2013 Azurite Black F10 M5
I've got it as well. Super annoying and very loud. Not even going to bother with the service department.
Besides, it only happens when I'm stopping at a red light downtown and a hot chick is in the crosswalk.
      12-07-2013, 06:16 AM   #51
py0413
py0413's Avatar
Drives: Slow
does the cold weather have a major contribution to making squeaky brake? because as the temperature drops to -5 these days, mine's making annoying noise every single time I touch the brake pedal. (btw, i had 31000km and hearing this squeaky brake noise for the first time)
Must stop eating..............
      12-11-2013, 11:33 PM   #52
cassidysdad
Does anyone know if the ceramic brakes squeak less? I have tried the hard braking it does work, but when I forget, my whole office can hear me pull in
      12-13-2013, 11:18 PM   #53
Orich
Drives: 2014 M5
I was told my SA that ceramic squeaks more before I ordered the car..
"Speeding is like farting - you have to know when it’s inappropriate." - James May
      12-13-2013, 11:20 PM   #54
Orich
Drives: 2014 M5
Originally Posted by AGS View Post
+1. About 3,500 miles and squeaks frequently when coming to a stop, once I'm below about 5 to 10 mph.
I have the exact same symptom, MY14, 900miles.
I'm almost due for break in service, but since it is infrequent not sure if I bring it up I can reproduce it at the dealer...
What should I do?
      12-14-2013, 08:24 AM   #55
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
What should I do?
They will tell you it's a symptom of the large, high performance breaking system. They have been instructed by BMW not to replace any brake parts. The only cure is to find a safe place to get up to speed and do a couple cycles of hard braking to clean the rotor surface. I did a track day on October 5th (lots of hard braking obviously) and my brakes have not squeaked since then.
      12-14-2013, 08:36 AM   #56
Spinny02
Spinny02's Avatar
Originally Posted by Lizard1
The squealing is getting worse and more frequent. I am planning on picking up a service tech after work today and ride with him - hopefully it's just some bad pads
Try a couple hard stops. Sometime a small rock/debris or something gets in to the pad. A few hard stops from a moderate speed will usaly clean then for a whole . If it only gets worse then change the pad.
      12-14-2013, 08:45 AM   #57
CFisher
Drives: F10 M5 Black Sapphire
I've only had my car in either semi-cold or freakin' cold weather so far...it didn't squeal so much in the semi-cold...but in the freakin' cold it def squeels coming to an intersection. Usually a quick lift of the foot for a split second and reapply will allow me to stop in silence. Never seems to be when I first start out...gotta be rolling for a little bit, then it starts. I'm at about 2000 miles now.
