03-11-2020, 11:57 AM | #1 |
Rep 402
CCB brakes
For the love of god can anyone tell me why these brakes literally squeal like a pig whenever I put any significant amount of pressure on the breast pedal. Omg it's so fuqing annoying. Sometimes they even do it at very low speeds when I'm not even hittin the brakes!!!!!!
03-11-2020, 12:12 PM | #2 | |
Rep 19,565
''Curing brake squeal''. |
03-11-2020, 01:42 PM | #3 | ||||
Rep 402
03-11-2020, 09:55 PM | #4 |
Rep 146
Didn't work at all for me. Will be returning the wheel cleaner.
03-12-2020, 06:14 AM | #5 |
Rep 170
You might start using the brake pedal instead of the "breast" pedal. My wife usually squeals when I press the breast pedal too! Ha ha!
Common issue with the CCB's, some of us just have a little chirp now and again, others have more squealing. There is a law suit that I believe is still active but BMW says these are performance brakes and the noise is "normal". You could probably change out to the regular brakes if you like or even better a Brembo kit but both would be expensive. Have you had them checked to make sure you don't need any components replaced? |
M5Rick60091.50 |
03-12-2020, 07:28 AM | #6 | ||
Rep 402
No I haven't. Just got the car last week |
03-12-2020, 02:53 PM | #7 | |
Rep 98
So basically, go take it out and really hit them hard and then see where you are at.... Also found that if the holes through the disc are filled up with pad deposit they squeak more. Get something like a long nail and poke through the holes and get the pad residue out.... Last edited by Butty45; 03-12-2020 at 03:02 PM.. |
Speenybean91.50 M5Rick60091.50 |
03-15-2020, 09:55 PM | #10 | |
Rep 11,891
03-22-2020, 09:33 AM | #11 |
Rep 184
My brakes squeak like HELL. Spraying them down with some cleaning products does help for short periods of time. Heat helps the most.
On a day where I do some spirited driving with heavy braking they minimize to nearly nothing. I have a M6 GC. |
