01-10-2016, 09:45 PM | #1 |
Rep 1,123
Looking for more power , Meth Kit Next?
Currently running catless dp's, turner exhaust and ESS tune . What can you guys recommend next to bump some more power out of it without upgrading the turbos. I'm thinking meth kit, any downsides ? Also which kit is popular that works on our cars?
2018 F90 BMW M5 Marina Bay Blue
2012 F10 BMW M5 Imperial Blue 2006 E60 BMW M5 Indianapolis Red 2006 E65 BMW 750i Titanium Silver 2001 E39 BMW 530i Orient Blue |
01-10-2016, 10:27 PM | #2 | |
Rep 313
01-10-2016, 11:33 PM | #4 |
Rep 313
01-11-2016, 09:45 AM | #5 | |
Hide! My wife's coming!
812
Rep 2,816
Once you've maxed out your power with the current setup, I believe your next step would be the following: JB4 + BCM - Push boost further than what the ECU is limited to Meth Tune to support the additional boos & meth. If you have DCT, you'll need clutch upgrades
01-11-2016, 04:34 PM | #6 | |
Rep 1,123
01-11-2016, 05:28 PM | #7 | |
812
Rep 2,816
In order to exceed that ECU limitation, you need the JB4 w/BCM and supporting tune to push it past that or upgrade the pressure sensors. You should see power levels exceed 700WHP which means youll need to upgrade your clutches if youre DCT If you are at 700HP Crank, I think you have a lot left on the table in just a tune. Making that assumption based on your signature which says ESS 700
01-11-2016, 07:43 PM | #8 | |
Rep 806
My car probably has bit more in it once the transmission is upgraded. I would recommend you address the clutch issue before adding more power. My clutches slip under heavy load. I'm thinking my next mod will bee ESS tune + JB/BCM.
01-12-2016, 06:54 AM | #11 | |
812
Rep 2,816
01-12-2016, 02:38 PM | #12 | |
Rep 1,519
And also if u end of stacking it. You will be limited with power (not to cross 690whp/trq ) as your clutch would start slipping. (Hence manual i have since stock clutch can hold over 800wtrq I suggest running boost juice also and prevent meth fire idc what people will say about installment lines or ss lines. It sjust safe imho |
01-14-2016, 01:00 PM | #13 |
Rep 966
First you need a clutch upgrade.
Stage 1 pure turbos then add the methanol with the JB4/BCM kit (required for the methanol control) You will probably have to ditch the ESS tune because a custom ECU flash will benefit you more or you can run the JB4 with meth and get more gains then what you currently get from ESS The ESS tune is a generic flash. They don't make a custom tune and I doubt they will be making more products for this engine soon as their focus is on S55 and newer models...I heard this from ESS directly when I spoke to them recently. |
01-14-2016, 05:04 PM | #14 | |
Rep 1,123
Thanks for the info but members here are saying ESS has a revised tune they can offer me to reflash. |
01-14-2016, 06:00 PM | #15 | |
Rep 966
I would call ESS and confirm on their stage 2 software and ask the details as I heard from them that it is not available yet. The backend flash is only for "piggy back" systems. And my note on a custom flash is because you can get better performance gains (more refined) rather then getting a pre-made flash that someone will load into your ECU. |
01-19-2016, 06:36 PM | #16 | |
Rep 18,808
By itself, the Backend Flash will not provide any additional power since it's not a tune. It will however give you the versatility of the piggyback options while allowing a bit more room for your piggyback to work from as well as other features piggybacks are not capable of delivering on its own.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
