      11-14-2016, 08:52 PM   #1
bmwdinan5
Drives: Dinan5
Engine Temp Difference based on throttle setting
I noticed today that when I run my throttle in efficient mode the engine temp is between 210-220F. But in Sport or Sport+ the engine temp drops to 175-180. Is this for fuel efficiency reasons, sort of like EcoPro mode in the 528?
      11-15-2016, 10:30 AM   #2
rambino
M Master
rambino's Avatar
Drives: M6 / X6M
Post Edited:
I stand corrected, in Sport + my temps drop 30 degrees!! The other 2 modes its variable and act the same.
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
      11-15-2016, 10:48 AM   #3
bmwdinan5
Drives: Dinan5
I've confirmed. I tested it in traffic and also 60MPH highway speed. (60F) In NON-M's the ECOPRO mode does a similar function as a higher engine temp makes the engine more fuel efficient.
I initially noticed it with the oil temp gauge and then plugged in my M performance Drive Analyzer to confirm.
      11-15-2016, 10:49 AM   #4
bmwdinan5
Drives: Dinan5
      11-15-2016, 12:18 PM   #5
kefler
Drives: 2018 X5m / Alpine White
I know on my 335i (N54) you could tell when it used the oil cooler or not.. Temp would rise to a point, then drop a bunch. I wonder if the modes here change at which set point it uses the oil cooler.
      11-15-2016, 03:25 PM   #6
Oliver Queen
Oliver Queen's Avatar
Drives: 2016 YMB/SO M3, 2016 F10 M5
I only notice the drop in sport +, in sport and efficient it stays around 210-220
Current Cars:
2017 GT350
2018 Mineral White M3
2015 ML63 AMG
      11-15-2016, 06:17 PM   #7
M5 London
Drives: F90 M5 LCI - Aventurine Red
The pump for the water charge cooler is only working full time (100 % of the time) in Sport +
In the other modes it only really kicks in when temps get really high.
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf
kefler122.50
      11-16-2016, 05:41 PM   #8
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
The temperature of the chargecooler water is not going to have any effect on the oil temperature of the car, which is what the OP is referring to.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      11-17-2016, 05:19 AM   #9
M5 London
Fair enough, but I couldn't agree to "ZERO effect" I could agree to negligible effect, and I was really just referring to this post :
I also notice the same behaviour. Perhaps the oil cooler has a valve / thermostat that opens to improve / maximise its efficiency in Sport + ?
      11-21-2016, 06:17 AM   #10
E90Fleet
South Africa
1312
All modern BMW engines run variable temperatures.
Its controlled via the ECU
Higher temperature for better fuel economy, lower temperature for more power
